Results 1 to 7 of 7
Thread: What is the best way to tighten large pipe fittings?
    Aug 2015
    Folsom Prison, CA
    124
    One of my fittings has a slow drip but it is too big for anything I have to get around and needs to be tighter than what I can do by hand. Does an oil filter wrench work or will I need a rubber strap wrench or something else?
    Jeff || 19,000g IGP || SwimClear 3025 Cartridge Filter || Hayward TriStar 1.39 THP pump || K-2006 Test Kit || 80% Surface Coverage Heliocol || Hayward Controller || Hayward Phoenix 4X4 || "Solar Rings" || PoolSkim
    Oct 2013
    Houston, TX
    32
    Re: What is the best way to tighten large pipe fittings?
    A strap wrench made with cloth/fabric works best for me. The rubber ones did not work for me as well. Look in the plumbing department. I think I paid around $14
    Andy49
    12K, IG, Plaster, DE, Install 1992, Spa, Polaris Sport, Rainbow Chlorinator 320, Taylor 2006
    30,432
    What kind of fitting? Is it a union?
    Aug 2015
    Folsom Prison, CA
    124
    It's the threaded union on the filter housing.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,764
    Craftsman 2 pc 16 Rubber Strap Wrench Set - - Amazon.com
    Strap wrenches work great for this...
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    30,432
    Hand tight should be all that's needed on unions. Did you insure the rubber 0-ring is installed on the mating surface?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    A little plumber's silicone grease might help also.
