Thread: Bleach vs Flagstone
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Bleach vs Flagstone
    This is a noob question but I don't know the answer. Does splashing chlorine bleach on flagstone coping bleach the rock? I started out assuming it would, but now I am not so sure. If I can confirm it does not affect the rock, this will make my bleach additions much less troublesome and worry free.
    30,000 gal free-form IG w/ spa, PebbleSheen Blue Surf, Pentair cartridge filter, Pentair 3 HP Intelliflo, extra pump that is way over-sized for weeping moss rocks, Dolphin Oasis Z5, municipal water, all built Jan-Feb 2016. TF-100, SpeedStir, Liquidator 3/8", borates. My build thread http://www.troublefreepool.com/threa...-in-Cypress-TX
    JoyfulNoise's Avatar
    May 2015
    13,254
    Re: Bleach vs Flagstone
    Bleach can affect stone in many ways depending on the constituents of the stone. Some flagstone has iron in it which gives it a reddish blush. Chlorine can definitely cause that to develop more into a brown color. I once splashed a small droplet of bleach on one of the stones in my waterfall and it took the color right out of it. That was 2 years ago and I can still see the spot today.
    If you're pouring around your stone, the best thing to do us wet the area down with some pool water to help dilute any splashes.
    Matt
    MarkTX's Avatar
    Nov 2015
    Cypress, TX
    337
    Okay, good to know. Thanks
