Thread: Pump injects debris into pool when starting in AM.
    Sep 2016
    amherst, MA
    2
    HI. I have a large in ground pool with a sand filter and like to shut down the filter at night to save electricity. Recently, when I re-start the pump in the AM yellow debris re-enters the pool for the first 2-3 minutes. Now I am vacuuming far too often. I always backwash after vacuuming and when I re-start the filter after completing the backwash, the water is clear when it re-enters the pool. I have lots of trees around the pool. My sand filter is at least 30 years old.
    alan
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Re: Pump injects debris into pool when starting in AM.
    Hi and welcome
    Have you tried deep cleaning your filter?
    http://www.troublefreepool.com/threa...-a-Sand-Filter
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,640
    Are you doing a 30 second rinse after the backwash setting?
    Sep 2016
    amherst, MA
    2
    Thank you very much for your response. The answer is "no". I have never tried that procedure in 25 years of cleaning the pool. Sounds like I should try that option?
    alan
    Hi. Thanks for the reply. I have never attempted that procedure. Would you be able to describe the procedure to me?
    Thanks for the help.
    alan
    Jul 2015
    Pittsburgh, PA
    98
    You might have a bad spider gasket as well. Ours was missing for a bit and each time the pump would turn on it would spit a little bit of sand and dirt into the pool. I purchased a replacement gasket and the problem was solved.
    In-ground 15x30 concrete pool with vinyl liner
    Triton II sand filter, Hayward Pump, Raypak 266 heater
    Rehab thread: Pool rehab, need advice
    Dec 2015
    443
    Sounds like you need to read this which describes the best way to backwash your filter (just click on the blue wording below)
    http://www.troublefreepool.com/conte...f-pool-filters
    To deepclean a filter read this post (which also has some handy videos of the process
    http://Have you tried deep cleaning ...-a-Sand-Filter
    notobik may be right, but once you open your filter to clean it it should be obvious is anything is not right. A broken lateral is another possibility. But lets just get it cleaned first as that should only take about an hour and see how it then performs. If it doesn't resolve the issue or if anything looks odd to Alan he can always post back here for more advice
