Thread: Trying to pull an old pool cover off to replace it for winter
    Hey guys and gals...
    Basically have a tarp like cover that sustained some holes in it over the winter to where if I try to throw a sump pump on the pool the pool water fills back onto the cover and I can never fully drain the cover to pull it to replace it.
    Getting ready to swap it for a new one and just probing to see if anyone has a better idea or has faced the same problem.
    A couple of years ago I tried the same thing and ended up dumping all the nasty water into my pool and took forever to clean up. Hoping to avoid that.
    Thanks in advance!
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    Re: Trying to pull an old pool cover off to replace it for winter
    Bump everyone.
    Really open to ideas...Seriously!
    -Jay
    20800 Gallons
    Sand Filter
    In ground
    1 hp pump
    Mod Squad pooldv's Avatar
    DFW, TX
    24,513
    I don't close or cover the pool but I do use a solar cover and sometimes it gets plenty of junk on it. I scoop as much as I can with a leaf rake and the rest goes into the pool. It is pretty unavoidable.
    Jun 2015
    Ottawa/Ontario
    340
    Pump as much as you can with sump. Scoop if you can with a bucket maybe? If you are that worried, put chlorine in water to sanitize it that way maybe?
    Assume pool is not operational? I ask because this past summer my solar cover got pretty mucky - after scooping a few leaves out, i brushed the water towards and directed it right into the skimmer...figured it was better than letting it all go into the pool directly...
    68,000litre, IG vinyl, LorentzPS 600 Solar Pump & 1/2 HP Tristar, Sandfilter, Aquarite T-15 SWG
    20000 gallon, IG, SWG, Sand Filter, Hayward 1/2HP + Lorentz direct solsr PV pump
