Results 1 to 9 of 9
Thread: Help with valve settings pool/ spa
    Sep 2016
    Chandler, AZ
    66
    Hi all
    I just bought a pre own home with a pool/spa
    I can't for the life of me seem to get the valve positions correct for normal use, cleaning (pool sweeper) and spa use
    The Jandy Valves were labeled at one time but he AZ heat has discolored them somewhat
    There are 4 Valves
    Spa suction - 1
    Pool suction / pool cleaner - 1
    Spa return / pool return - 1
    Spa (something faded) - 1
    Attached is a picture of the equip
    11,300 gal/ IG - Pebble tech pool & Spa / DE - Hayward Filter/2.0 HP pump single speed / Hayward cleaner/ built in early 2000's by California Pools / Taylor K2006 test kit
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Help with valve settings pool/ spa
    Welcome to TFP!
    The pump suction line on the left is currently set for spa OFF, turning it 180 will close off pool suction and open spa suction. So, in the pic the suction is coming from the pool. The middle pool suction line is also OFF. If you turn the pooo valve counterclockwise it will open the middle pool suction line and Cloe the right pool suction line.
    Sep 2016
    Chandler, AZ
    66
    Thanks for the reply
    So for normal operation cleaning and filtering what should they look like?
    What should they look like for spa use only?
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Forgot that the spa only use valve, turn is 180 degrees counter clock wise. I'm guessing they have them set for counter clock wise turn.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Sep 2016
    Chandler, AZ
    66
    Thanks for your help
    I will work with that and see how she blows
    Keep you posted
    Apr 2015
    Camarillo, CA
    39
    When I had my pool put in a couple of years ago I was SHOCKED to find the valve handle convention is different than the "normal" valve handle convention. When the valve handle is perpendicular to the pipe, the valve is open. I still get confused when I look at my piping. Make sure you understand the relationship of valve handle position to the direction of flow. Wonder why they did it that way.
    April 1, 2015 first fill of infinity edge of about 15,000 gallons. Aqua Blue Pebble Sheen, iAquaLink, Jandy 2 HP variable filter pump, Jandy 2.5 HP single speed feature pump, Jandy CL580 cartridge filter, Jandy heat pump, Jandy propane heater, spa of unknown size, 3 LEDs in pool, 2 LEDs in surge pond and 1 LED in spa, Eclipse EC-10 Del Ozone oxidizer and 4 Jandy laminars with Jandy CS100 filter built by California Pools in 2015.
    Jul 2015
    Houston, TX
    89
    Quote Originally Posted by ps0303 View Post
    Great job figuring out that mess of piping! After looking at your annotations, it makes a lot of sense, but no way I could have figured that out by myself.
    25,000 gal, in-ground, plastered gunite, Pentair NSF 60 DE Filter
    Sep 2016
    Chandler, AZ
    66
    That's what I said
    He knows his stuff
    Great job circling and labeling
    Saved me a call to a pool guy
    You guys are a true help
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    BTW, the one valve I failed to circle would allow you to divert more water back to the pool and less to the spa spillover. In most cases you do sort of just have a small spillover and return more water back to the pool.
    Paul
