Thread: Hayward Tigershark problem diagnosis
    Sep 2016
    Chapel Hill, NC
    1
    Hi all - longtime reader, first time poster.
    I've got an about 4-5 year old hayward tigershark that I inherited from the previous owners of the current house. When I started using it over this past summer, I had to go ahead and replace several parts to get it up and running (one side, both rubber treads, several bearing guide rollers, the impeller), but at that point the tigershark was working just fine. Recently, when I turn it on it does it's initial 3-4 second power-up cycle, then stops, then runs again for another 3-4 seconds then stops completely. I'm trying to figure out what the issue could be now - I've disassembled the cleaner again and there's no debris or other structural issues I can find. According to the troubleshooting manual it could either be the motor or a power issue (I'm assuming a power issue could be the power supply/controller box or the floating power cord). Any advice/insight on how to diagnose the exact issue? I don't have a multimeter or a hayward error code scanner, either.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    Re: Hayward Tigershark problem diagnosis
    Mechanical issues are usually easily serviced on these robots, but electrical issues are a different story. It's likely to cost you some $$ but you're better off taking it to a local retailer that sells and services Hayward products. aka, the dreaded pool store. The manual for the TigerShark is pretty detailed. Almost a service level manual. http://www.hayward-pool.com/images/p...ting-guide.pdf If you're unable to fix it with that, it's likely to the point where you need to replace the cord, the motor or the power supply. A service center will be able to test and isolate the problem and replace the offending component. Sounds like the unit is sensing low or high resistance loads on the components, not allowing it to complete the diagnostic start up.
    Isolated Spa - 345 Gallons
    Jun 2017
    White Rock BC
    7
    It must be spring! I have the identical symptoms after 5 "trouble free" years of service since new. Outwardly , no visible issues, ie filters,tracks etc. I was wondering if you had success in repairing the unit and if so what the issue was.
    Thanks in advance.
    pauloharris's Avatar
    Apr 2015
    Nashville TN
    13
    Having the same issue.....any words of wisdom
    1st time pool owner. pool was installed 2011. in ground fiberglass, 15k gallons, all jandy equipment (pumps, heater, SWG aquapure 1400, Dolphin robotic cleaner).
    May 2018
    St Charles
    1
    Hey guys! Had the same issue. Took the filter cartridge out, then ran it in the pool. Thinking the extra water flow cleaned whatever jammed it out. Works fine again. Last year it wouldn’t run at all. Had to get new drive pin. $40 fix at local pool store.
    Jun 2017
    White Rock BC
    7
    Quote Originally Posted by Ktustin88 View Post
    Thanks Much. Will try that.
