Thread: Leak in pool pump housing?
    Jun 2010
    Wilmington, NC
    19
    I am posting a picture of my pump housing to show where water is leaking out. There is a glob of marine putty where I attempted to seal what seemed like a pinhole. That lasted about 3 weeks! You can see where the water is dripping down and I also noticed a pool of water up near wear the white pipe is coming into the housing. Can anyone tell what part I am looking at trying to replace? Also good place to purchase online or pool store?
    Thank you for your time and advice!
    Lisa
    hoskim's Avatar
    May 2016
    Berkeley Heights, NJ
    83
    Re: Leak in pool pump housing?
    Went through a similar exercise (although my leak was at the bottom) and this is what I would do (I am a first year owner so I am sure others have more insightful comments):
    1. for the "pinhole" - you may have worn-out seals (connected to your impeller) and replace them (you can search youtube and that's what I did) I bought my parts on Amazon - Amazon.com : Pool Pump O-ring Seal Repair Kit For Hayward Super Pump SP2600, 1600, 2600X Kit 3 : Swimming Pool And Spa Parts And Accessories : Patio, Lawn Garden
    2. AND replace the gasket that comes with the kit
    3. as for the "top" - I am having a same issue with my polaris pump pipes and going to removed / reinstall / reglue - I am going to do some research on this
    25,000 Gal, in-ground w/ vinyl liner
    Hayward SP2303VSP (1.5 HP) / DE filter (4820)
    Aqua Rite SWG / T-CELL-9 (v1.5)
    Polaris 380, PB4-60 Booster Pump (post-2012) / Aqua Heat Pump (S95)
    TF-100 Test Kit with Speedstir
