Thread: fading/staining around edges
    Jun 2013
    Irmo, SC
    37
    We are getting a light yellowish stain or fading (not sure which) around the edges of our liner on the floor of the pool. Anyone know what this is?
    12500; sand; IG; vinyl; Tf-100 test kit
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Re: fading/staining around edges
    Pics and test results?
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,774
    Light yellow staining usually indicates iron.
    Crush up a vitamin c tablet, put it against one of the floor stains for a good 5 minutes or so, and tell us if that removes the stain where it sat.
    Are you on a well? Do you treat with metal sequestrant at all (sometimes called stain and scale)?
    If you've previously used a metal sequestrant and now are getting light staining, its a sign you need a maintenance dose.
    How do your stairs look? Have they yellowed? (Another sign of iron.)
    With iron or copper, staining is more likely at a higher ph, and lowering your ph to around 7.2 will help prevent further stains.
    Right now the trick is to determine if its metal, and if its specifically iron for best steps forward.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
