Results 1 to 7 of 7
Thread: Gunite Pool Builder Recc in South Jersey/Favortie Equipment
    Sep 2016
    Voorhees, nj
    3
    Hey guys, I am new to the form and considering a new construction of a gunite pool in 2017. Have a bunch of questions so please bear with me. Looks like I will be having a free form gunite in-ground pool roughly 38-40ft long x 18-20 ft wide (haven't confirmed size yet) with a attached raised spa. Live in Cherry Hill NJ area.
    Question 1: Pool Builder Reccs: Was trying to get recommendations on which builders to have come by for a quote. Some of the more reputable builders in the area are as follow: Van Brill Pools, Brunetti Pools, Swim-mor pools, Budds Pools, Anthony and Sylvan, Seasonal World. Was curios if you guys have and experience with these builders in regards to quality of build, workmanship etc?
    Question 2: If starting from scratch, what is some of your favorite pool equipment per category and pool upgrades if you could do it all over again? I want to keep long term costs and efficiency in mind when choosing equipment to keep recurring bills as low as possible if equipment upgrade is worth the cost. I have put in parenthesis things I am leaning toward based on forum perusing for a while.
    Filter: (lean toward cartridge; Jandy or Pentair?)
    Pump (Lean toward VS Pump- ?Pentair Intelliflo?)
    SWC (?Autopilot?)
    Heater for Pool/Spa - (?Heater vs Heat Pump) [If heater Jandy LXi vs Jandy High E2)
    Deep End Depth Recc (No diving board in pool so debating 6-8ft)
    Deep End Drainage - Deep end Drains (2) vs Deep water outlets at corner of deep end side wall junction
    Pool Plumbing - Leaning toward at least 2.5" on the suction side and 2" on the return side; individual runs for 2 skimmers and main drain
    Spa Recc: 8 jets, ?Own Var Speed speed pump, Air Blower
    Spa Plumbing: install 3" return and suction
    Auto Fill:
    considering a waterfall feature leading to evaporation
    Safety Cover Recc?
    Thanks so much in advance
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,638
    Re: Duplicate post
    Hi!!!! I am glad to see a new pool to build and spend money on!!!
    TFP is mainly a forum to teach people how to care for their pool. Saying that the under construction part has grown quite a bit. I am telling you this to help you understand why there almost no companies named here. We have found it causes less problems in the long run.
    You are welcome to PM anyone to ask who their builder was. Most people have their location by their names.
    Equipment-both brands are good. Some people have found they get a better warranty if they buy a package deal. Just something to think about.
    I think you could learn a lot from reading some build threads. They will give you a good snapshot of what is about to happen in your life!
    Aug 2014
    NJ
    435
    Re: Gunite Pool Builder Recc in South Jersey/Favortie Equipment
    I have an autopilot SWG. Very happy with it but it is not compatible with my AQUALINK automation. In retrospect I wish I went with the Jandy SWG even if it is not as good because I would prefer to be notified of any issues In real time
    One of the builders you mentioned Subs out all the work (which I think is a negative in terms of scheduling and warranties) and makes you sign a waiver when you use a SWG and have stone work. Both of those issues precluded me using them.
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    JoyfulNoise's Avatar
    May 2015
    13,254
    Good luck on your PB search. Remember, the best way to vet a PB is through references. When you start calling in PBs for quotes, ask them to provide references for pools both recently built (within a year) and pools several years out. Then call those people on your own (don't let the PB handle the contact) and get a feel for both the quality of work, the professionalism of the process and any pitfalls. A good PB will happily supply a book full of references. References, references, references...
    As for equipment, you'll will do best to keep it all in the same manufacturer. So either all Pentair, all Hayward or all Jandy. Mixing and matching is a recipe for compatability problems. Personally I like Pentair but their stuff is definitely more pricey than the others and their warranties are more strict.
    Matt
    Sep 2016
    Voorhees, nj
    3
    Thanks so much for your replies, I truly appreciate it. Wasn't sure whether to keep all same manufacturer of try to get best manufacturer of each piece. Whats your thought on plumbing reccs as well for pool and Spa
    May 2015
    13,254
    Quote Originally Posted by duke33 View Post
    Honestly speaking, if I could redo my pool, I would get rid of the attached spa and add more of a Baja deck/sun shelf with bubblers and build a separate slab for a stand-alone hot tub. I don't use my spa nearly as much as it should be used so it's kind of waste.
    Was there something specific about a spa plumbing you were considering?
    Matt
    Esloser's Avatar
    Jun 2016
    Millville, NJ
    393
    Would also recommend taking a look at Landi Pools & Spas out of Vineland, NJ. He offers a complete package including cover and closing it and opening it the following year.
    SWC (?Autopilot?)
    Auto Fill:
    Safety Cover Recc?
    36,000 Gallon Inground (IG) Gunite Pool with Spa and 12" tanning ledge | White Plaster | Cartridge Filter | Hayward Single Speed Pump (x2) | 400k BTU Hayward Heater | Hayward ProLogic Automation | Taylor K2006 Test Kit | In-pool Cleaner | August / September 2016 Build Date | Build Thread
