Thread: Size Pipe and material to put in walkway for volleyball net?
    Aug 2016
    Baltimore Md
    49
    I'm thinking 2" pipe in the walkway on both sides of the shallow end for volleyball nets. 2" sound right? Plastic or metal conduit? It will be cut flush or recessed a little under pavers? This is all new to me
    Thanks!
    Jan 2015
    las vegas
    92
    Re: Size Pipe and material to put in walkway for volleyball net?
    AquaStar 7-1/2 Umbrella Stands with Sleeve and Center Cap Blue | US104
    This is what is normally used, has a cap so when volleyball net is not used you are just not left with open holes. They can be set in concrete then papers set around.
    Aug 2016
    Baltimore Md
    49
    Thank you!
