Results 1 to 11 of 11
Thread: Changing to cartridge -- need help with sizing 18x33 above ground
    Sep 2016
    Leesburg, GA
    4
    Hello,
    I want to change from sand to cartridge due to too much sand getting in the pool. It's a new 18x33, 54". I have a few questions. I'm currently running a Hayward Power Flo LX 1.0 HP piped up with 1.5" PVC.
    1) How many sq. feet of cleaning surface do I need? I want near-overkill here and don't want to wish I had gotten something bigger.
    2) Can an in-ground 4-cartridge system work? Something like the Hayward C3030 or a similar Pentair? The input/output fittings are on the same side of the canister on those and that situation works best for my pump/filter location.
    3) If I need to stick to single cartridge filter cannister system, what make/model/sq. footage would you recommend?
    Thanks in advance for some advice here.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,081
    Re: Changing to cartridge -- need help with sizing 18x33 above ground
    Hi, welcome to TFP
    When it comes to cartridge filters, there is no such thing as overkill. The bigger the filter, the less you will have to clean it.
    The large 4 cartridge filters will work fine on your pool. I would say go with a bare minumum of 300ish sq feet. If you go bigger, then that's even better.
    hope this helps,
    Divin Dave,
    Sep 2016
    Leesburg, GA
    4
    absolutely Dave, thank you for the quick response. I'm ready to pull the trigger on one and wanted to make sure there was no reason that it wouldn't work for me. Dave, will my 1.0 hp pump keep things moving in a large 4-filter cannister?
    Dave, what about the Hayward SwimClear vs the Pentair Clean and Clear? Know anything about those pro/con?
    Sep 2016
    Leesburg, GA
    4
    Mod Squad pooldv's Avatar
    DFW, TX
    24,742
    Yes, your pump will be fine with a cartridge filter. My C&C 520 works fine, no experience with Hayward. The C&C 320 is good.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,081
    Mike,
    your pump size is fine. No worries at all. Just dont be surprised that with a very large filter, the pressure gauge will read lower than you might expect. Don't worry though, thats normal and its because the larger filter has less restriction of water flow through it.
    Both the Hayward and Pentair filters work equally well. I prefer Pentair because I like the fit and finish better than the Hayward and I like the pentair air release valve better than the Hayward one. It just seems more robust to me. I have the Pentair CC 420 and love it.
    Divin Dave,
    JoyfulNoise's Avatar
    May 2015
    13,399
    You may find this thread informative as it has lots of useful info on how to size pool hydraulic equipment - Hydraulics 101 - Have you lost your head?
    Matt
    KatyTXPoolOwner's Avatar
    Jul 2015
    Katy TX
    94
    I have the Pentair Quad DE 100 and couldn't be happier. Water is extremely clean and it's very easy to maintain. As Pentair says, the clarity of DE with the convenience of cartridges.
    23,000 gallon gunite chlorine pool / spa .. French Gray Pebble Sheen .. IntelliFlo VF main pump .. IntelliFlo VS spa booster pump .. WhisperFlo 1HP water feature pump .. LA01N .75HP cleaner booster pump .. Letro Legend Platinum cleaner .. Quad DE 100 filter .. MasterTemp ASME HD 400k heater .. Rainbow 320 chlorinator .. 1.5HP blower .. Easy Touch 8 remote control .. 8 Twirlybyrd jet spa .. Paralevel .. TF-100 w/SpeedStir
    May 2015
    13,399
    Quote Originally Posted by KatyTXPoolOwner View Post
    I don't backwash mine anymore. I simply tear it down twice per year. So in that sense it's a lot like an oversized cartridge filter with the added benefit of DE filtration.
    Matt
    Sep 2016
    Leesburg, GA
    4
    Went with the 3030 and the results are unbelievable. Crystal clear!!! Thanks for all the help and input you all, you are a blessing.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,081
    That's awesome! Glad we could be of assistance.
    enjoy
    Divin Dave,
