Thread: Another newbie with pH problems
    Gappy's Avatar
    Sep 2016
    Mt Gilead, Oh
    3
    Question Another newbie with pH problems
    My pool is green and has been most of the summer. I've tried the pool store treatments to bring down the pH but they haven't worked. On their advice I have treated for phosphates, used algeacide, multiple shock treatments, etc. I've been studying the Pool School info, so I am ready to SLAM the pool, but need to adjust the pH first. Today I added 3 quarts (96 ozs) of muriatic acid but to no avail. My test results are:
    pH 8.0 acid demand 5 drops to lower to 7.0 (I know that's too low but I accidentally added an extra drop)
    TA 120
    CH 220
    FC .5
    CC 1.5
    CH 220
    CYA 30
    This is my first time using the test kit so I hope I interpreted it right, but it seem in line with pool store test and strips.
    Any ideas that may help?
    17,100 gal 27' round AG pool, Hayward power-flo lx pump 1.5hp, Hayward Dreamliner 175lb sand filter, Hayward vari-flr xl filter valve, Taylor K-2006 test kit, fill from well, Wanda the Whale vacuum cleaner
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Re: Another newbie with pH problems
    Hi Gappy,
    the pH kit can only test up to 8.2. If the kit reads 8.2, it may well in fact be much higher than that. So, what to do?
    All we can do, and recommend, is pretend the ph is 8.2, add some acid, wait 20 minutes and test gain. Repeat the process until the pH test starts to respond.
    Divin Dave,
    Gappy's Avatar
    Sep 2016
    Mt Gilead, Oh
    3
    Thanks for the input. It may sound silly, but is there a fairly simple formula to tell how long it takes to mix the chemicals throughout the water for a true test result? Your suggestion was the only thing I could think of so good to know I'm on the right track.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    15 to 30 minutes usually does the trick. You can brush to help even more.
    Gappy's Avatar
    Sep 2016
    Mt Gilead, Oh
    3
    Thanks, I'll get started first thing tomorrow.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Welcome to the forum!
    I have moved this thread into a more appropriate forum instead of the Supporter Area. No harm done, just letting you know.
    Essential Links:
