Results 1 to 8 of 8
Thread: spa plumbing detaills
    Sep 2016
    India
    4
    Hello friends, I am from India
    just joined TFP, while researching on Google, and found it to be very informative
    Recently made a pool in the house, now that was easy with the plumbing and fitments, now my friend wants me to make a pool with spa at his site.
    pool is not a problem but got entangled with the spa part.
    requires round shaped 10 jets placed 5 on upper level and other 5 lower. I would be highly obliged, if some one could help me with the technical details.
    In India there are practically no know how how to go about.
    Redards
    Apr 2015
    tucson, arizona
    1,137
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: spa plumbing detaills
    I have also put together quite a bit of information here:
    Hydraulics 101 - Have you lost your head?
    I can also help but need a lot detail about the equipment you plan to use, especially the spa jets. Different types of jets require different flow rates so that needs to be decided first. Also, with jets, you will have a hard time using a single pump to run all jets. Even the smallest jets require 10 GPM each so 100 GPM total so you would need a very large pump for that.
    Mark
    Sep 2016
    India
    4
    Quote Originally Posted by mas985 View Post
    Thank you, mas985
    The information on post, thread and the articles referred were of great help, and i manage to find a supplier who has forwarded me the jets products, and mentioned the flow rates also 17 liters/min that is about 4.5 GPM. file attached for reference, but the expansion kit for gunite installation is not available with him.
    i have to figure out how to install the kit in the spa concrete.
    and yes we here have not gunite facilities the shell of pool and spa has to be done by on place casting method. forwarding the spa air water tee and jets available here.
    regards
    the pdf file is being loaded i am tying, is there is any other way i can forward you
    thanks
    mas985's Avatar
    Pleasanton, CA
    11,742
    You can put it on the cloud (Google Drive, OneDrive, DropBox, etc) and post a link to it.
    Mark
    Sep 2016
    India
    4
    Dropbox - PAGE 31.pdf forwarding you the pic of air water tee and nozzels specifications, i am making an air water mix extension tee combination and send you the link soon to be installed in gunite or concrete lay our as the one required is not available here.
    regards
    Sep 2016
    India
    4
    drop box pg 31 now working please take a look
    mas985's Avatar
    Pleasanton, CA
    11,742
    Quote Originally Posted by mansoor View Post
    Those are extremely low flow jets. I don't think I have ever seen a spa jet with that low of a flow rate. I am not sure how well they will work but it shouldn't be an issue to run 10 at once on a single pump.
    Mark
