Thread: Aqua pure says LO but temp is 85
    Sep 2016
    Richardson texas
    1
    My Jandy Aquapure says "LO" on the box readout. Additionally, the remote says high salt, when I believe the salt level is good.
    the J-box red and green lights are flashing alternately. Any idea how to fix this so it will generate chlorine.
    when I hold down temp button at wall, it rolls through numbers quickly (all below 50). Any help is appreciated.
    Jun 2011
    Long Beach, CA
    2,784
    Re: Aqua pure says LO but temp is 85
    Welcome to TFP!
    Most likely the sensor needs to be replaced or cleaned. Make sure the cell and sensor are clean and double check to make sure all the connections are good.
    Here is a link to help you troubleshoot the system, https://premium.zodiacpoolsystems.co...ce3d54eb51.pdf.
