Thread: Winter cover patching
    May 2016
    Toronto/Ontario/Canada
    68
    Hi, I have some holes in my winter cover that I would like to try to patch for this winter season. The cover is made of fabrene material and the holes are small in worn out spots in the cover. Are there any recommended brands for the patches to get? I found the following on amazon though they do not seem well reviewed and seem way more expensive than I thought they would be. Anyone has any experience with them?
    Swimming Pool Winter Cover Repair Patch Kit: Amazon.ca: Patio, Lawn Garden
    Rola-Chem BS-1-24 Ultra Strip Swimming Pool Covers Repair Patch: Amazon.ca: Patio, Lawn Garden
    Otherwise all other patches I found state they are for vinyl covers and so I am not sure they can work for fabrene covers. Any thoughts on this?
    Thanks!
    In Ground Chlorine Irregular Shape (21,000 gallons), Cartridge filter Sta-Rite S7M120, Pentair 342001 SuperFlo VS, Vinyl Liner , Gas Heater Raypak P-R265B-EN, Test Kit Taylor K-2006, Filled with Tap Water, NO Spa, Several large trees towering the pool, Pool and equipment several years old but look in reasonable shape
    Re: Winter cover patching
    Not sure this is appropriate for your issue but we used a product called Plasti-dip that saved our safety cover that the squirrels had chewed on. Ours cover had lots of tears and holes so we bought a couple gallons at about $70 per gallon but it did the trick and should last a few more years. Note: the small spray cans don't go very far.
    Good Luck.
    Gary R.
    18 X 32 Oval Inground Gunite Pool 20,000 Gallons Epoxy Painted in 2012
    Tagelus Sand Filter TA 60 D/TA 60-Hayward Super Pumps 1 H.P.
    Ray-Pac Heater 266,000 BTU, KLeen Machine Pool Cleaner
    Solar Cover-Rocky's Pool Cover Reel-Intermatic T104R Timer
    TF-100 Test Kit-PoolSkim Skimmer
    May 2016
    68
    Thanks Gary, that's actually pretty interesting. It did not cross my mind to try something like this though it makes a lot of sense. I have a few half inch holes. I will look into this further. Thanks again!
