Thread: Pentair control panel SERVICE error.
    gatorbrit's Avatar
    Aug 2013
    Raleigh,NC
    95
    This morning my pool pump wasn't running. I checked the Pentair EasyTouch Panel and it said "SERVICE". I cut off all the breakers and turned them back on but now the panel breaker won't turn on. Basically the panel has no power.
    I have had a bad light - and I wondered whether it shorted out and blew a fuse.
    I am going to call for help. But just wondered if anyone had any suggestions as to what might be wrong.
    Also - anyone suggest a maintenance guy in the Raleigh, NC area?
    Thanks
    18k vinyl IGP, Sand Filter, EasyTouch Control Sys, Pentair Intelliflo, Intellichlor IC 40 SWG, Rheem Heat Pump.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,541
    Re: Pentair control panel SERVICE error.
    Gator,
    The first thing I would try is to reset the pool Circuit Breaker in you main power panel.. the house electrical panel that is providing power to your EasyTouch.
    If your EasyTouch has an external electrical receptacle in the lower right side, I'd look at it. It will be a GFCI outlet and is often used to supply power to internal EasyTouch circuits. Make sure the GFCI is reset.
    Unless you have a volt meter, that is about all I can suggest..
