Results 1 to 9 of 9
Thread: Do I need to shock?
    Do I need to shock?
    It seemed like every time I did the FAS-DPD test I couldn't tell if my CC was .5 or 1 - so I decided to try the test with a 25ml sample. Here were my results:
    pH -7.6
    CYA - 70
    FC - 6
    CC - .8
    I didn't do TA today but last it was 100 a couple days ago.
    Two questions:
    1. Is it fine that my FC is a little higher than recommended for my CYA?
    2. Do I need to shock at a CC of .8? I thinks it's been hovering at that for a while now.
    18'x52" All Resin AG 8,200 Gallons, Vinyl 35 Gauge Liner, Installed August 19th 2016
    Krystal Clear™ Sand Filter Pump 14" with 1,600 gallon (6,056 L) per hour flow rate,
    120v Krystal Clear Saltwater System Cg-28663 with ~UNPLUGGED~Copper Ionizer
    Located in NY - TF100 Test Kit - K-1730 Taylor Copper Test - Taylor K-1766 Salt Test
    **Learning more than I could have imagined here... Thank you!**
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,096
    Re: Do I need to shock?
    How does the water look?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Water looks perfect... Do I need to worry about letting the kids swim in it? Today might be one of the last hot days of the season.
    Jul 2014
    Hope Mills, NC
    567
    They are good to go
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    Thanks! I doubt we'll have many more pool days this summer so I want to squeeze in as many as possible... I'll keep an eye on it and if it gets up to 1, it will be my first SLAM!
    Aug 2014
    Northern IL
    4,615
    Good luck, and have fun!
    I just have to say, I love this site I find myself constantly on here just trying to learn and understand more. My pool looks perfect and everyone here is so nice and helpful. My hubby makes fun of me because I love using my new test kit LOL I'm actually about to go outside and get a sample to run a full set of tests now!!
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    It is safe to swim with FC above minimum and up to shock level for your CYA, FC/CYA Chart, so don't be nervous at all about running FC a couple of ppm higher if you are seeing a little CC. Raising FC up to halfway between target and shock level will help clear up whatever is causing the CC.
    Thank you pooldv- I actually unintentionally raised it a bit in the past couple of days. I changed my SWG from 4 to 5 hours a day thinking I would need it because of the warm weather, but turns out I didn't. I just finished testing and here's what it was tonight:
    pH 7.6
    FC 8 - a little higher than the 5 I need for my CYA
    CC 0
    TA 110
    CYA 60
    CH 25
    Salt 3400
    Thanks again for the info, I'd rather throw in some bleach and have it be totally clean than run the risk of anything icky being in the water!! Especially knowing that it's still safe to swim with high FC.
