Thread: C1900 DIY question
    Oct 2015
    Frisco, TX
    75
    C1900 DIY question
    I'm considering options for having chlorine added to the pool by a Stenner pump. I am avoiding the pucks due to the CYA they add to the pool. However, I am thinking that by using a Stenner pump we can add chlorine to the pool throughout the day and just fill up the 30 gallon container monthly (or something like that).
    I am currently thinking of two options:
    1. Install the C1900, given what I've read though, the ORP calculations do not seem to be all that reliable. The forums have had some discussion about this product. What I don't get is how the C1900 powers the stenner pump. Are two separate outlets run from the power center, one for pH and one for bleach? And is the C1900 able to control the outlets through some kind of configuration? If so, what is the configuration in iAquaLink?
    2. Just add an outlet that is controlled by the PowerCenter and schedule times for when the Stenner pump would run. Given the issues with the life of the Stenner pump decreasing because the variable speed is adjusted down, I think I'd just get a fixed speed Stenner pump and have the PowerCenter control it.
    In either case I'd still monitor the Chlorine levels closely using the Taylor test kit.
    Any thoughts?
    Thanks
    16.4K gal, IG Pebble Sheen, 2 X 2.7 Jandy HPPlus VS pumps, 580 sq ft Jandy cartridge, ozone, completed 4/2016, iAquaLink, Dolphin M500, Lamotte WaterLink Spin and Taylor K-2006 (to verify WaterLink), Jandy 400K JXi Heater, Jandy Nature Fusion 2 with 3" TriChlor tablets
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,550
    Re: C1900 DIY question
    Scott,
    I believe that the simpler the better, so I'd go with the fixed feed Stenner controlled by a timer. Just have to be sure to use a timer that would allow for multiple on/off cycles per day.
    Mar 2013
    maryland
    139
    I use an orp/ph system, but my pool is mainly covered so less variation, lower cya. I have been happy with it. Orp can be variable and finnicky,but when dialed in it really works beautifully.
    " A little knowledge is a dangerous thing"
    19,000 gallon sylvan pool, Easytouch 2 4p automation, Screenlogic interface, Intelliflo VF 3050 pump, Intellichem with Intellichlor 40 chlorinator/Muriatic acid, Raypac millivolt natural gas heater.Polaris pool cleaner with booster pump.Coverstar automatic cover hydraulic mechanism with PCS cover. Wet edge Luna quartz finish 2016. Northeast climate.
