Thread: filter pump
    Sep 2016
    Kilgore
    8
    filter pump
    We bought our neighbors intex above ground pool. it's the standard 15ft 4ft deep. We were able to get it set up without difficulty. it has a salt water pump as well. We are having issues with the filter pump. it turns on only for a few minutes than shuts off. We have reset it (which turns it back on for about 2 to 3 minutes) than shuts off again. we have released air from the pump several times, and I have fixed the skimmer to make sure it was not clogged or connected wrong. please help.
    kyla mae
    May 2015
    Clarksville
    146
    Re: filter pump
    it sounds like the plug may need to be replaced. I had that this yr with out sand filter. if you change out the plug on the end, it'll no longer have that test and reset feature, but will still run properly. they wear out after a while.
    vinyl soft sided pool
    intex 1500 gph sand filter and intex swg at 1500 gph.
    Sep 2016
    Kilgore
    8
    Re: filter pump
    ok thank you! where can you replace the plug at?
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,091
    Re: filter pump
    Umm, I'm not sure if you should do that. The plug is a GFCI plug and the shut off is a safety feature. Hold on and let some of the more electrically minded folks show up here to talk to you about this.
    Edit: Or at least replace with another GFCI plug.
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    Sep 2016
    Kilgore
    8
    Re: filter pump
    ok i dont have it plugged into a gfr outlet. and the test button keeps flippingetting, causing the pump to turn off
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,091
    Re: filter pump
    I think you should post another thread and this time use "problem with GFCI plug on Intex pump" as your title.
    That should get you more help.
