Results 1 to 7 of 7
Thread: Pool drained, now refilling. Now what's first and second on chemistry balancing
    Sep 2016
    Houston, TX
    31
    Hi experts, I had a high cya issue (maybe 140) and I drained about 70-80%. Now I'm refilling and I'd like to know what to focus on first, second, third, etc. Refil is coming from city from my three hose bibs. I'll test as soon as it gets fill but curious what I tackle, in what order. Appreciate the help. Will post numbers as I get it filled. I've never done a drain and refill so I don't know how long it's gonna take.
    15K gal rectangle with 1K gal spill over round spa | K-2006 Test kit | IG plaster | B2983 1.5HP 2 speed pump| Triton TR100 sand filter | Pentair MiniMax 400k BTU heater | Stenner 45MPHP10 w/ 15g tank | Dolphin M400 robot | screened pool cage covers pool entirely to keep it debris free and adds SPF | sun exposure estimate 8hr daily.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    Re: Pool drained, now refilling. Now what's first and second on chemistry
    The order we ask for test results is fine, it really isn't important, which is why it isn't specified anywhere
    FC - Free Chlorine
    CC - Combined Chlorine
    pH
    TA - Total Alkalinity
    CH - Calcium Hardness
    CYA - Cyanuric Acid (stabilizer)
    Borates - (if you are using borates)
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,528
    I recommend tackling pH first, then CYA, followed by FC/CC. Then TA and CH.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Aug 2014
    Northern IL
    4,615
    Post up those numbers and we will go from there. It really depends. If your pH is out of whack, that's going to be your first priority. Let's see where you are. Please add that you have a K-2006 to your signature.
    Sep 2016
    Houston, TX
    31
    Refill done, I've got pump circulating, here's the numbers:
    FC 4
    CC - less than .5
    pH - 7.5
    TA 130
    CH 170
    CYA b/w 40-50
    I plugged my numbers into pool math and looks like I need a little bleach, some soda ash to get the ph up, and a decent amount of calcium chloride (used troublefree #'s as the baseline). What do you advise I do now and in what order please?
    Oh, and as for how the water looks, I'd say maybe a tiny bit cloudy with a hint of aqua green. I can easily see to the bottom (5ft at max depth), it's just not that sparkly blue and clear like I'm used to. I'm sure chemistry will get me there.
    Aug 2014
    Northern IL
    4,615
    Re: Pool drained, now refilling. Now what's first and second on chemistry balancing
    I would use a CYA value of 50 for poolmath and get your FC up to 6 first. I would leave your pH alone for now, it's fine. Yes to the CH.
    You could try an OCLT tonight to see if the cloudiness/green is due to something in the water and go from there.
    Chasmengr's Avatar
    May 2016
    Omaha, NE
    156
    When I filled mine from scratch from city water hose bibbs, I concentrated on FC and circulation with a cautious introduction of CYA, which you already have. Filling took a total of ~30 hours (about three calendar days at ~10 hrs/day), so keeping growing things from gaining footholds because of inadequate chlorine was my goal. After fill, I added in other testing and balancing to achieve swimability and stability.
    Chas & Cheryl (first-time, third-year pool owners)
    Radiant Metric Oval AGP 16'x32'x52"; Pentair: Clean&Clear 150 Cartridge, OptiFlo 1.5 Hp 2-spd, and 320C Feeder (all mounted below water level); Taylor K-2006 & SpeedStir; Maytronics Dolphin E10 (aka Einstein)
    installation pics (2015-2016)
