Thread: UV and chlorine
    ka8yiu's Avatar
    Aug 2016
    SW FL
    121
    UV and chlorine
    I take it that the culprit during the day that causes the loss of chlorine is UV. Now in the south the UV is a year-round issue. However, the UV index may still max out lower in the winter months.
    So, has anyone with a year-round pool noticed a measurable decrease in the amount of chlorine lost in the winter vs. summer?
    8K gal IG Fiberglass (San Juan Waikiki I)
    TF-100 Testing Kit
    Hayward Max-Flo VS Pump
    Hayward Star Clear Plus Cartridge Filter
    Pentair Model 320 Automatic Chlorine/Bromine In-Line Feeder
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: UV and chlorine
    There are other factors at play here, for one thing chlorine consumption greatly drops off with temperature decrease, this happens fairly dramaticly once the water goes below about 60F
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    Re: UV and chlorine
    +1 to that colder water, less sun, shorter days equals far less FC consumption.
    JoyfulNoise's Avatar
    May 2015
    13,201
    Re: UV and chlorine
    Short answer is yes. The sun is lower in the sky during winter months so there is a measurable drop in incident UV radiation. Temperatures are cooler and algae reproduction rates are insignificant below 60F.
    During the winter my SWG shuts off due to cold water. I typically use less than 3 gallons of bleach over 4 months.
    Matt
    Jul 2015
    Tempe, AZ
    194
    Re: UV and chlorine
    Yes - far less FC use in the winter even here in AZ.
    In fact I got so complacent with it last winter, that in the spring when the days got a bit longer and we got a bit warmer, my pool took on a funny green color from the algae.
    John - 16,000 gallon | in ground | pebble | Triton II sand filter | TF100 | speedstir | Hayward Phoenix 2x
