Results 1 to 9 of 9
Thread: Shocking With Granular CL in SWG Pool
    Apr 2009
    Orange Park, FL
    104
    I have 2 large tubs of granular tri-chlor. Will I harm the SWG if I add the granular CL through the skimmer? Right now I need to raise my CYA and CH and I'd like to use up at least some of the granular tri-chlor that I have left whenever possible.
    FC = 3
    PH = 7.7
    CYA = 50
    CH = 50
    15x30 IG vinyl liner pool, pool cage
    Hayward S-220T high rate sand filter and Hayward super pump w/1hp motor
    Hayward SwimPure Plus SWG
    Polaris 380 cleaner and booster pump
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Shocking With Granular CL in SWG Pool
    I recommend that you dissolve it in a bucket of water and then pour it in front of the return.
    Apr 2009
    Orange Park, FL
    104
    Prior to installing the SWG, I always added the tri-chlor through the skimmer, so I'm not familiar with how quickly it will dissolve in a bucket. Is it fast dissolving?
    Jan 2009
    Cupertino, CA
    1,966
    I have never used the granulated trichlor but based on my experience with the pucks, I think hot water would dissolve it pretty well. Unless somebody knows it dissolves okay in a bucket of pool water.
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2007
    Coastalish 'down easter'
    4,160
    Just a quick point here: tri-chlor is tablet (or pellet) form and I think we're talking about Di-chlor here. The difference isn't large, but there is one
    Anywho, predissolve it and slowly pour in front of an active return. try not to let any of the undissolved gunk go into the pool - if there is some in the bottom of the bucket, stop pouring and add more water, mix and let it dissolve before adding it 8)
    Luv& Luk
    -Ted
    Apr 2009
    Orange Park, FL
    104
    The label says tri-chlor. Its Aquachem from Lowes. I went ahead and tried to dissolve it in a bucket of pool water but it didn't dissolve well - lots left in the bottom of the bucket. So I just did my old normal routine and poured it through the skimmer with the SWG off. I'll keep the unit off until tomorrow.
    Sorry Waste, wish I would have seen your post prior to losing my POP!
    I have seen granular trichlor. Trichlor isn't great to use for shocking because it dissolves so slowly. Also, keep in mind that trichlor adds CYA and lowers the PH. Sometimes that is convenient but far more often it results in too much CYA and rapidly falling PH.
    Apr 2009
    Orange Park, FL
    104
    Precisely for those reasons (+ CYA and - PH) is why I decided to use up some of the tri-chlor. My concern was adding it via the skimmer now that I have a SWG.
    Jan 2009
    Cupertino, CA
    1,966
    As long as the pump is on until the trichlor is all gone, putting it in the skimmer should be okay. You don't want it sitting in the skimmer with no water flow.
    --paulr
