Thread: The Pool Calculator Sticky Link
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    I am a little confused why we have "The Pool Calculator" sticky link at the top of the forum. The standard answer from the long time members has been to use the "PoolMath" link at the top of the page since it is updated and avoid "The Pool Calculator". It just seems confusing to me (and probably other newbies) to have the calculator sticky'd if it is not a TFP recommendation.
    Am I missing something?
    P.S. the intention of this post is to be helpful, not critical. I am just trying to understand this one inconsistency.
    19328 Gallon Above-Ground Pool. Clean&Clear Pentair Cartridge Filter. Opti-flo 2 Stage 1.5hp Pump. Dolphin Nautilus Plus "Flipper" Robot. Established April 2016. Taylor K-2006. Chlorine Based. 340gallon Marquis Spa. Bromine based. Established 2007.
    pabeader's Avatar
    May 2015
    Cartersville Ga
    4,112
    Re: The Pool Calculator Sticky Link
    I'm not seeing the it. Or maybe my view is not set up properly. Can you do a screen shot of it?
    Bob - INTEX 12x24 owner, 'New to me' Kreepy Krauly Sand Shark, Test kit: TF-100 w/Speed Stir
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Link goes to poolcalculator.com
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    I'm not sure why it's still their either. Pool Math is the page to use.
    Reported this issue for moderator discussion.
    Isolated Spa - 345 Gallons
    Administrator Leebo's Avatar
    Jul 2011
    Eastern Ohio
    7,113
    Quote Originally Posted by Holydoc View Post
    The answer to this is very likely simple......we missed this one. I've removed this sticky at this time until we can figure out a better way to fully deal with it.
    Great catch!!!!
    Holydoc's Avatar
    Jul 2016
    Navarre/FL
    258
    Quote Originally Posted by Leebo View Post
    Great catch!!!!
    Just didn't want people to get confused. After all the help this group has given me, it is nice to be able to help a little.
