Results 1 to 11 of 11
Thread: Pool builder says 3" pipe is waste of money
    57cheby's Avatar
    Aug 2016
    Montgomery tx
    51
    I told builder I want 3" suction and return lines on spa and I also had them run 3" suction on pool drains. I have Pentair intelliflo 3hp vsp. He tells me I'm wasting my money. I have read on here of people complaining about low pressure on spa because of pipes too small. Builder says all I need is the 2.5" to spa. I know it's on here somewhere but can't find it tonight. To all the pros would you run 3" pipe to and from spa?
    installing 8 jets 15 gpm each.
    Started 9/5/2016 In ground gunite pool, 43x15, salt, Pentair intelliflo vsp 3hp x2, booster cleaner pump, Polaris cleaner, intellitouch 8, led color logic lights, 400k btu heater, spa, wet edge technologies Luna Quartz finish, travertine noche coping, 3.5-6.5 ft deep
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Pool builder says 3" pipe is waste of money
    How many jets will you have?
    How much flow rate per jet?
    Mark
    57cheby's Avatar
    Aug 2016
    Montgomery tx
    51
    8x 15 gpm I just edited post. Thanks
    mas985's Avatar
    Pleasanton, CA
    11,737
    Sorry one more. How long are the runs?
    Mark
    57cheby's Avatar
    Aug 2016
    Montgomery tx
    51
    I can measure in the morning but guessing 40ft each way.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The first issue i see is that you need 120 gpm for all jets. The Intelliflo won't be able to do that even with 3" pipe.
    But even if it could then you have the issue of pushing 120 gpm through a filter. With that many jets, you really need a stand alone pump for only the jets. The spa should have a separate filtration loop from the jet loop.
    Mark
    May 2015
    Fullerton, CA
    635
    I have 3" section on pool and spa, 2" returns 6 jets, the spa run is 65 ft. 1 pump, plenty of spa jet action.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    57cheby's Avatar
    Aug 2016
    Montgomery tx
    51
    Thank you both for your help. I had 9 jets put in and after reading on here where some people didn't have enough pressure I ran out side and had him cut one out, should have stuck with 6. PB is also using a 2hp blower and said usually has to turn pump speed down cause jets are too strong. I will go ahead and do 3" suction and 3" return and hope for the best is all I can do at this point. Thanks again
    Isaac-1's Avatar
    SW Louisiana
    6,711
    There is really no down side to oversizing the plumbing except for the minor increase in up front cost. Within certain sane boundaries large plumbing is always better with lower flow restriction, which in theory you will get back eventually on electrical savings / increased efficiency. The only factor here is that as pipe size increases you get a case of diminishing returns so that the payback time on "savings" may be years or decades.
    57cheby's Avatar
    Aug 2016
    Montgomery tx
    51
    My thoughts exactly. The PB made me second guess myself. Thanks for your help
    KatyTXPoolOwner's Avatar
    Jul 2015
    Katy TX
    90
    I insisted to my PB that he install 3" return and suction for my 8 TwirlyBird jet spa (about a 50-60' run) and I'm fortunate that I stood my ground. Just my Pentair VF pump and Blower would not supply nearly enough spa jet action. He ended up installing an additional Pentair VS pump in the spa only loop and the spa has fantastic spa jet action. I'm not sure if 2" or 2.5" suction/return would have the same result.
    23,000 gallon gunite chlorine pool / spa .. French Gray Pebble Sheen .. IntelliFlo VF main pump .. IntelliFlo VS spa booster pump .. WhisperFlo 1HP water feature pump .. LA01N .75HP cleaner booster pump .. Letro Legend Platinum cleaner .. Quad DE 100 filter .. Max-E-Therm 400k heater .. Rainbow 320 chlorinator .. 1.5HP blower .. Easy Touch 8 remote control .. 8 Twirlybyrd jet spa .. Paralevel .. TF-100 w/SpeedStir
