Thread: Minimax NT STD 300 heater - replace or repair
    While troubleshooting an igniter problem, I noticed that the bottom of the burner tray is VERY rusty and that 3 out of the burners do not sit horizontally, because the back bracket completely crumbled (so the far end of the burner dropped.) I ordered the igniter before thoroughly looking at the unit, but now I am thinking it might be time to replace. I can probably fabricate a back bracket if I can figure out how to access the back of the unit. The unit functioned well so far and the burners look totally fine.
    And advice would be greatly appreciated.
    Guy
    ~20k gallon IG plaster pool, Pentair 3/4HP Whisperflo, Pentair FNS Plus 48 DE filter, IntelliClor IC40 Salt Generator, Pentair Legend Platinum Robotic Cleaner
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    Re: Minimax NT STD 300 heater - replace or repair
    You are at the point where you need to consider replacing the unit as the burners are not being held in place. You would have to totally dismantle the unit in order to even see if you can make something but then you have to consider if it's worth it as you might end up a few months down the road with a totally rusted out unit.
    Replace it with a Raypak and swim warm and happy.
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Quote Originally Posted by ps0303 View Post
    I see that Hayward does not have many fans in this forum despite the mostly stellar Amazon reviews. Any objection to Pentair Mastertemp? Any opinions about Sta-Rite?
    Guy
    ps0303's Avatar
    Jul 2011
    FL
    3,703
    With my years being around these units fixing and replacing them, I can tell you that Raypak is the most solid unit currently on the market. Raypak has the fewest moving parts which in turn means fewer headaches down the road.
    I replace lots of blower motors, keypads, and system boards on all Pentair units.
    Paul
