Results 1 to 8 of 8
Thread: Heavy Rain, do I need to shock?
    May 2009
    NC
    136
    We've had some extremely heavy rain over the last 2 days, so I was wondering do I need to shock? Is there actually a schedule for how frequently to shock (ie. weekly, bi-weekly, monthly, etc.) or is it on an as needed basis? I haven't shocked since I finished up my Baq conversion, have just been testing daily and raising FC to 4 in the evening so that I still have around 2 the next evening. Just want to make sure the excessive rain doesn't send my water out of control. Thanks!
    24' Round 52" High AG, Waterway 125 SF Pro Clean 2HP, 2 SPD Cartridge Filter
    Pool Rover Jr. /TF-100 Test Kit/ BBB - Ex Baqua User
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Heavy Rain, do I need to shock?
    have you tested your water? that would be the answer. otherwise, it's just a blind guess. if you want one, my blind guess is probably not.
    edit: also, the excellent pool school article has reasons to shock. otherwise, it's not really necessary unless you're following a different pool care method. pool-school/shocking_your_pool
    You don't normally need to shock. After a storm it is a good idea to add a little extra chlorine, to help take care of the extra debris that got into the pool, but shocking is not normally required. If the FC level actually goes to zero, then you should shock. Usually that doesn't happen.
    May 2009
    NC
    136
    Thank you.
    Here are my test results: (haven't added any bleach since yesterday evening)
    FC 2.5
    CC 0
    TC 2.5
    pH 7.5
    T/A 100
    CH 60
    CYA 30 on Monday, but I added a little on Wednesday because I had to add some water because of evap.
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by stephanie4136
    I thought you had rain? You don't lose CYA from evaporation (I wish!) the only reason to add more is it's too low to begin with, or because you're removing water (backwashing, splashing, draining out rainwater, etc).
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2007
    Morris, IL
    477
    This is what I do, I add about half again as much, maybe double the chlorine after a storm. The only time I really shock per say is after a heavy party weekend with alot of people in the pool. But I don't really test shock levels, I just basically triple the normal dose. Being exact is really only necessary to clear up algae IMHO. If you can prevent it, pool maintenance is easy.
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    May 2009
    NC
    136
    Quote Originally Posted by PaulR
    --paulr
    I added the water before we got the rain (didn't realize we would get so much!), after the rain it was actually above the skimmer so I had to drain some. The kids always splash out quite a bit, plus I figured we had some loss due to evap because the sun is right on our pool until late evening. I only added a very small amount of CYA because I thought I needed to since I had added some water.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Stephanie...if your chlorine is 2.5 FC I would add enough to get it up to 5-7 ppm if you have had a heavy rain that will take care of any extra organics that are floating around. Other than that i would not shock...I used to shock every weekend last year with Cal Hypo...But at the extra prodding for Frustrated Pool Mom, i have been trying to go without doing that. She says I shouldn't have to...I did just for a little extra...but at this point this year we have not been in the pool but three or four times...so I haven't seen as much usage...But I plan to not use the Cal Hypo if i can avoid it...
    get that FC up!!! and you'll be fine
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
