Thread: New pool build, noticed pumps are not bolted to the pad.
    Jan 2016
    76
    How many of your pumps are physically bolted to your concrete pad? My PB just finished the job, and I noticed when cleaning the baskets the other day that the pumps are not bolted down to the pad. When I smack the lids to get them off, the whole pump wiggles and is really only held by the plumbing. Seems to me this would cause added stress on the housing and plumbing. Should I have them bolted down?
    -J
    KatyTXPoolOwner's Avatar
    Jul 2015
    Katy TX
    90
    Re: New pool build, noticed pumps are not bolted to the pad.
    Good question as mine are not bolted down either. I'm interested in the answer, too.
    23,000 gallon gunite chlorine pool / spa .. French Gray Pebble Sheen .. IntelliFlo VF main pump .. IntelliFlo VS spa booster pump .. WhisperFlo 1HP water feature pump .. LA01N .75HP cleaner booster pump .. Letro Legend Platinum cleaner .. Quad DE 100 filter .. Max-E-Therm 400k heater .. Rainbow 320 chlorinator .. 1.5HP blower .. Easy Touch 8 remote control .. 8 Twirlybyrd jet spa .. Paralevel .. TF-100 w/SpeedStir
    Jul 2015
    Landale, PA
    107
    Mine are not bolted either. Neither is my filter, heater or 30 gallon tank of muratic acid.
    To be built Spring 2016. 750 sq foot gunite free form. Raised spa with spillover and dedicated pump, 16 foot fiberglass slide built into hill with bolder steps, approx 1,000 sq foot stamped concrete deck, Pentair VS+SVRS pump, Sta-Rite 400,000 btu gas heater, Sta-Rite System 3 cartridge filter, Pentair Intellichlor IC60 SWG, Pentair Intellichem, Pentair Easytouch, Rapids 4WD pool cleaner, 2 LED Intellibrite lights.
    Feb 2015
    Chandler AZ
    933
    Mine isn't bolted down either. And none I've seen in my area are either (not to say there aren't some out there that are). If you have to "smack the lids to get them off", you may be over tightening them or need to re-lube the lid O-rings. Do your lids have a tab on either side to aid in removal or are they a different design?
    Please fill out your signature to reflect your pool and pool equipment as outlined here: Pool School - Read This BEFORE You Post
    Gene
    ​12,300 gal IG play pool - Pebbletec - built 10/1999 || Hayward S360SX 36" sand filter || Hayward Ecostar SP3400 VSP || A&A In-Floor cleaning system || Quik Water Leveler || Quik Dek-clor (limited use)
    TF-100 testkit / Speedstir - A good test kit is not an expense, it's an investment
