Results 1 to 8 of 8
Thread: Old Chlorine
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    167
    Old Chlorine
    I've read here in several places that I want to make sure my bleach is fresh, or it isn't effective...
    My question is, if I use an old bottle of bleach will it still register on a test as FC giving a false sense of security, or will it just take a lot more than it should?
    Chris | 16' x 34' 16,000 gallon | IG Vinyl | Pentair Tagelus sand filter | Jandy 2hp epump | AquaPro PRO1300 heat pump | Coverstar auto cover | Taylor K-2006 | built August, 2016.
    aswarren628's Avatar
    Jul 2016
    St. Louis, MO
    26
    Re: Old Chlorine
    It'll just take a lot more than it should. This thread gives good info on this subject. Breakdown of bleach over time by storage temperature - Page 2
    Andy - 30' oval (13,500 gallons) IG, Painted Concrete, concrete surround. Pentair Sand Dollar SD4 sand filter and Pentair Pinnacle PFII-PI 3/4 HP single speed pump. Using Bleach/MA/Baking Soda and Taylor K-2006 Test Kit.
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    167
    Re: Old Chlorine
    Thanks... so I'll keep any extra I have after closing, and use it up next spring accordingly... I printed out Chem Geek's chart - wow, and thank you to him and the time on his hands!
    Aug 2014
    Northern IL
    4,615
    Re: Old Chlorine
    It will degrade even more by spring. If you use it now, which I recommend, you can test a half hour or so later and see where your addition ended up. Then you can work backwards in PoolMath to see the effective strength of the old stuff.
    Sep 2013
    Connecticut
    728
    Re: Old Chlorine
    We move the left-over pool chlorine to the laundry room at the end of the pool season, diluting it with an equal part water for laundry use.
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    cjpwalker's Avatar
    Aug 2016
    Yakima, WA
    167
    Re: Old Chlorine
    Quote Originally Posted by singingpond View Post
    Yeah, laundry here is on an ozone generator ("activated oxygen" if you ask the marketing folks...) so we rarely add anything else. Only have a couple of gallons of bleach, but I'm going to stick with pucks for the rest of the season to get my CYA up.
    Like I said, I'll pour it in the pool rather than throw it away. I can deal with weak - just wanted to make sure it didn't go bad.
    Sep 2013
    Connecticut
    728
    Re: Old Chlorine
    No, it doesn't go bad. We had some left-over 12.5% last fall (more than what we used on laundry over the winter). When we opened the pool in June I used the left-overs, and found it seemed at about the strength of supermarket bleach (5-6%). Worked fine, just had to use more.
    May 2016
    Troy IL
    476
    Re: Old Chlorine
    It doesn't go bad, and if you store it out of the sun and heat over the winter, it'll still be plenty strong by spring. It just won't be as strong as it was new. I'd save it indoors and use it to open the pool in the spring, then buy new to start daily dosing.
    17,500 gallon IG Vinyl
    Pentair Tagelus TA60D Sand filter
    Pentair Challenger 1.5HP pump CFII N1 1.5A
    Taylor K-2006-A, Stenner 45MPHP10 auto chlorine feed
