Results 1 to 13 of 13
Thread: Help! Pump leaking like crazy, trying to find a replacement!
    Sep 2016
    Lancaster, CA
    87
    I apologize, as I was planning on spending some time writing my first post and getting settled in here, studying and reading as much as a could but now I have an emergency! I was planning on upgrading my pump to a VS speed anyways and starting researching, when last night my pump started draining the pool onto the ground! So now I'm in a rush trying to figure out what to do, I need to be able to get something here overnight, or go down to leslies and buy.
    It's a 14k gallon pool, has a heater, equipment is about 25 feet away at ground level. Current pump is a superflo single speed 1 hp. No other features. I'm trying to stay under $1k and I'll do the install myself. I live in Socal desert, so very high energy costs.
    This is the main one I'm looking at, is this a good choice?
    Amazon.com : Hayward SP2302VSP Max-Flo VS Variable-Speed Pool Pump Energy Star Certified : Patio, Lawn Garden
    Any other recommendations?
    Apr 2016
    Riverview, FL
    239
    Re: Help! Pump leaking like crazy, trying to find a replacement!
    Not enough knowledge to say if it's a good pump or sufficient for your needs as I'm just getting started with my first pool - but if you but it be sure to check other sellers that sell "Fulfilled by Amazon". Depending on your location you can save $$ by avoiding sales tax. Just checked and direct purchase with Amazon was $769 + $53 for tax. Purchase through another seller and you get same shipping but avoid the tax (save $53). Good tip if you buy another pump / model.
    Free Form 13K IG (Quartz) w/Screen Enclosure - 2 Sheer Descents, 1 Bubbler - Hayward 60 SF DE Sta-Rite - Hayward SP3400VSP EcoStar - Hayward Aqua Rite AQR9 (T-Cell-9) SWG - Zodiac MX6 - July 2016 - Taylor K-2006 - Taylor K-1766 Salt Test
    Sep 2016
    Lancaster, CA
    87
    Thanks for the tip!
    ~14k Gallon IG Plaster (old)
    Hayward DE 4280 Filter
    Pentair Superflo SS Pump
    Built 1993
    Old Broken Heater that needs to get replaced!
    I have a 1hp 2 speed Hayward. I'm about 10000 gallons maybe a bit more. Why is the pump you have so expenisve? I think I paid 175 or so for mine through amazon
    12' x 24' (21100 gal) Doughboy Desert Spring w/ Deep End, Hayward SP15922S Power-Flo Matrix Above-Ground Pump 2-Speed,
    Hayward S210T Pro Series, Hayward H100ID1 H-Series , Hayward AQ-TROL-RJ AquaTrol Salt, TF-100
    Sep 2016
    Lancaster, CA
    87
    Quote Originally Posted by Wraenking View Post
    Sent from my SM-G900V using Tapatalk
    I want to upgrade the whole thing to a VS pump...not sure I get the question.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,491
    How about a VS Superflo? The 342001 is 1-1/2 hp. 650 bucks here, Pentair SuperFlo VS Pump 342001 | Pentair 342001
    Sep 2016
    Lancaster, CA
    87
    Quote Originally Posted by pooldv View Post
    I was avoiding them because of the self install warranty only being 6 month.
    Anyone have experience with Speck Badu EcoMV? Speck Badu EcoMV 2.4 HP Pool Pump (EcoMV/72-V) - 2072266213 - INYOPools.com
    DFW, TX
    24,491
    I've never heard of that brand. If you know and electrician who can make an inexpensive service call a receipt from an electrician will get you the warranty.
    Sep 2016
    Lancaster, CA
    87
    Suppose I could, still costs $$. Any reason to go with Pentair vs Hayward?
    Built 1993
    Sep 2016
    Lancaster, CA
    87
    Here's the leak!
    Built 1993
    DFW, TX
    24,491
    You may have to re-plumb with the Hayward. That's a pretty good leak!
    Sep 2016
    Lancaster, CA
    87
    I'm going to re locate it anyways, to get the footprint smaller for the equipment.
    Sep 2016
    Lancaster, CA
    87
    Quote Originally Posted by Uavmx View Post
    Bought the max flo, can't wait any longer.
    Built 1993
