Thread: How do you manage pool covers?
    Aug 2016
    Merrimack, NH
    26
    Lightbulb How do you manage pool covers?
    My AGP is freezing! I have a solar pool cover, it's opaque, that I can use to help heat the pool.
    My problem is the thing is a PITA to manage. Once you take it off you have a huge wet sheet of plastic that you can't leave on your grass to dry (doh, tried that, NOT a good idea unless you like crop circles of dead grass).
    What do you guys do? Where do you dry it? Do you just toss it in your basement sopping wet? All folded up and stuff, I don't think it'll ever dry.
    13,600 gallon (round, 24' diameter, 4' deep), above ground, Pentair OptiFlo 1.5 HP 2S pump, Pentair EasyClean ECDE90 filter, TF-100
    Jun 2011
    Long Beach, CA
    2,781
    Re: How do you manage pool covers?
    For daily swimming, I have a reel next to the pool that I wind the cover onto. There is no need to dry it off as it goes back on the pool each night.
    For long term storage, you need to dry the cover and store it out of the weather.
    There are members with homemade reels, try searching the forum to get some ideas.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,470
    Here is the local favorite diy solar cover roller.
    DIY Solar Cover Roller
    Apr 2015
    Niskayuna, NY
    63
    I think that most agree that the solar cover is a pain with an above ground pool. It's harder to use a reel unless you've got a whole lot of deck around the pool to put the reel on. I have no personal experience with them, but I do see that they sell smaller solar covers that you can use multiples of to cover your pool. That way, they are easier to manage when they are off. I have a neighbor that has these for her inground pool and she drapes them over her fence when they aren't on the pool. It kind of creates a privacy fence out of her aluminum picket fence.
    http://www.intheswim.com/p/solar-sun-rings
    18x36, 21,000 gallon, in-ground, vinyl, Pentair SWG, DE filter, Pentair 250K Heater, Taylor K-2006, Dolphin Triton
