Results 1 to 10 of 10
Thread: Repair or Replace Hayward heater
    Jan 2014
    El Paso, TX
    38
    I have a Hayward H400IDL heater for about 10 years. Yesterday I noticed the heater exchange started leaking. Do you think it is a good idea to replace it or just repair it? I have 40k gallon salt water pool.
    thanks
    Omar
    42' x 25' Gunite Pool, 10' x 10' Spa, Horseshoe wading pool around spa, 40,000 gallons
    Hayward Aquarite SWG, Pentair IntelliFlo VS Pump 3HP(main) 011018
    Hayward Pump (spa), Hayward DE Filter, LED Lights, Waterfall, Granite Tile
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Re: Repair or Replace Hayward heater
    No question about it, replace it. Get a Raypak unit.
    Paul
    http://www.gastekservice.com If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Check out some videos on my YouTube channel - http://www.youtube.com/c/Gastekservices
    Jan 2014
    El Paso, TX
    38
    Quote Originally Posted by ps0303 View Post
    what size and what model would you suggest? The 400k btu unit seems to take forever to heat the pool.
    Also where would you buy it? My pb suggested to replace also, but quoted $2900 for a raypak or pentair.
    thanks
    Omar
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    400K is the largest BTU you can buy for home use.
    $2900 for a 400K Raypak installed?? I've seen them well over $3K installed.
    Paul
    Jan 2014
    El Paso, TX
    38
    should I get the cupro unit or the asme unit? I am not sure what unit he quoted me for.
    thanks
    Omar
    Quote Originally Posted by omsrex View Post
    To be fair, you're not operating at optimal efficiency with a leaking heat exchanger. A 400K btu should be fine for your pool.
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Jan 2014
    El Paso, TX
    38
    it just started leaking this sunday. It has always taken forever to heat.
    Omar
    Jun 2012
    western NY
    1,562
    At 40,000 gallons, a 400,000 BTU heater will only get you 1 deg/hr of temp rise
    Unknown make 18' above ground (bought used in 1999) Sparco sand filter. Hayward 100,000 BTu heater. 2 speed pump
    Jan 2014
    El Paso, TX
    38
    is there a commericial sized heater that you guys would recommend that would heat more quickly?
    Omar
    ps0303's Avatar
    Jul 2011
    FL
    3,708
    Just get the 400K Raypak as a commercial unit will be way too expensive to install. NO you do not need the cupro nickel heat exchanger. Just take care of your water and keep it balanced and you will not have any issues.
    I have never seen where a 400K unit wasn't large enough for a residential pool. If you want to help your heat ups and also retain your heat better, buy a solar cover for your pool and keep it on during the cool months.
    Paul
