Thread: Pool Anti freeze Propylene Glycol Vs with Ethanol
    Central Connecticut
    159
    Regarding use of antifreeze (with ethanol) in return/suction lines when closing pool.
    Home Depot sells 2 brands of RV AntiFreeze that also advertise for pools. (both rated at -50degrees)
    One is Dow RV & Marine AntiFreeze $4.98/gal Primary Ingredients are Water 64-70%, Propylene Glycol 25-30% No Ethanol
    Other is UG Uni-proof RV & Marine Antifreeze $2.98/gal Primary Ingredients are Water 70-80%, Ethanol 10-20%, Propylene Glycol 3-5%
    I am concerned that ethanol will effect the PVC piping used in my pool system. Does anyone know if Ethanol is a problem with PVC ... rigid or semi-rigid pvc?
    Thanks
    Rich
    18x36 IG 26,000 gal, Vinyl Liner, 24" Sand filter Hayward S224T, Jandy AE3000 heatpump and 1.5 HP SuperPump. Circupool RJ45 SWG
    JoyfulNoise's Avatar
    May 2015
    13,193
    Re: Pool Anti freeze Propylene Glycol Vs with Ethanol
    Ethanol should not be used. I'm not worried about PVC, it's anything with a rubber seal that ethanol can destroy. Stick with the stuff that is propylene glycol only, it will do fine.
    Matt
