Thread: Mustard Algae help
    Jul 2012
    Forest, VA
    79
    Mustard Algae help
    About 5 days ago I noticed a few baseball sized spots of yellowish stuff on the hill of my pool and a line of it on the crest of the hill. I assume this was mustard algae. At one point last week I had let my FC down to 2 which is below min. I brushed it up and got FC to 13-15 to host a party. After party on Monday:
    FC 6
    pH 7.4
    Alk 90
    CYA 50
    So I poured 3 bottles of 8.25% bleach in which should've brought FC to 30. (Must alg level). Filter on 24/7, brushed twice left overnight. Tested this morning and I'm at FC 27. Should I add more bleach or let gradually come down to SLAM level of 20 and try OCLT? Thanks for replies.
    12,000 gal Octagon vinyl in-ground pool. Hayward S220 sand filter 3/4 hp pump, heat pump heater
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Mustard Algae help
    OCLT will work fine at any FC level above 3 ppm.
    Jul 2012
    Forest, VA
    79
    To be clear, my question was whether or not to bring FC back up to 30 (must algae shock lvl) or let come down to reg shock level. I will OCLT Thurs night.
    30,431
    Come back up to 30 ppm....give it a big dose is the best.
