Results 1 to 10 of 10
Thread: High TA with SWG but pH seems to be steady???
    So I got my TF100 about a week ago and I've been trying to get all my chemistry into the recommended range for a SWG. Here are tonight's results:
    FC: 8.5
    CC: .5
    TA: 100
    PH: 7.5
    CYA: 55
    CH: 25
    Getting closer!!!
    I'm in the process of dissolving the 2nd half of my CYA in a tube sock in my skimmer, it's almost gone. I leave it in there even when the pump isn't running - is that okay? I've read a lot of conflicting views here about that. Once I get my CYA up to about 70, I'm going to adjust my SWG, I don't think I need as much run time. I'm shooting for a FC level of 5ppm.
    My pH seems to be holding steady (I think). Over the last couple of days it's been around 7.5. When I first got my test kit I had to add MA to bring it down from 8.2. I ended up lowering my TA as well from about 110 to 100. If my pH holds steady, do I need to worry about bringing my TA down even further? Or should I just be happy where I am and not mess with it? I've been doing a lot of reading and I don't want my pH to drift or to put any unnecessary strain on my SWG cell. I just don't like adding MA, I'm terrified of it!!
    Other than that, the water looks great. I'm in the northeast and we're getting a lot of rain from Hermine right now - does the rain raise or lower the pH?
    Thanks in advance!!!
    18'x52" All Resin AG 8,200 Gallons, Vinyl 35 Gauge Liner, Installed August 19th 2016
    Krystal Clear™ Sand Filter Pump 14" with 1,600 gallon (6,056 L) per hour flow rate,
    120v Krystal Clear Saltwater System Cg-28663 with ~UNPLUGGED~Copper Ionizer
    Located in NY - TF100 Test Kit - K-1730 Taylor Copper Test - Taylor K-1766 Salt Test
    **Learning more than I could have imagined here... Thank you!**
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: High TA with SWG but pH seems to be steady???
    If your PH is stable then your TA is fine. Rain usually raises PH through aeration.
    Okay, so I'll just keep an eye on it for now. If it goes up again, I'll bring it way down to about 7.0 to see if I can lower the TA some more. I was hoping you would say that �� LOL
    DFW, TX
    24,450
    Yep, that is a good plan.
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Your SWG will raise your ph also. You will be adding ma every couple days.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    I want to avoid frequently adding MA as much as possible... Lowering the TA should help to keep the pH steady, right? Does anyone have any experience adding borates? I read that will also keep the pH down, but I'm a newbie so how difficult is it? What do you do if the borate level gets too high?
    DFW, TX
    24,450
    Borates won't get too high unless you add too much. First, see if your PH is steady with TA as is. Then if it continues to rise lower it 10 ppm or so and see how pH reacts. If you get TA to 60 ppm and PH is still rising you can add borates to help slow pH rise.
    More here, Borates - Why and How
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    807
    I've never had to add MA, and my PH has been steady at 7.5 since my last drain (to lower CYA). That was a few weeks ago. TA is 70. Every time I test it I expect to see an increase, but I don't.
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    I've been monitoring it every day and the pH hasn't moved, neither has the TA. I'm going to let it ride until there is an issue.
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    807
    Yep, me too, Lynndi. Don't fix what isn't broken!
