Thread: New above ground pool owner
    Aug 2016
    Reading, Pa.
    1
    Hello and thank you for the useful and informative information thru this site. My 18 foot round is about 3 weeks old now. Once filled, I put in some conditioner that came with the pool package and have been using the pucks as well. Read up on a lot here and bought myself a Taylor kit.
    My numbers have been good so far, I think :
    FC 7
    CC 0
    PH 7.6
    TA120
    CH 200
    CYA 47
    So I am stopping the pucks now as from reading here it will only raise my CYA to a level I do not want. I am armed with the non-additive bleach bottles and know to use the pool math calculator.
    My question is how often do I now perform the tests?
    Do they all need the same frequency?
    Thank you again for all past and future help.
    Dave
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    827
    Re: New above ground pool owner
    Starting out on the right foot!
    i test chlorine daily, when I am not traveling. The rest, weekly. Rains a lot here, so I keep my eye on CYA.
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,520
    It's best to test daily at first, until you get a good feel for how much chlorine your pool consumes in a day. Then once you're comfortable with it, you can start to go 2 or 3 days without testing. Just continue to add the normal amount of chlorine each day.
    Since your CYA is still at a manageable level, your target FC is only 5 and your minimum 4. You can measure this easily with an OTO drop test daily, and save the FAS-DPD reagents for a weekly test once you get it all stabilized.
    FC and pH is all I check on a daily or semi-daily basis.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
