Thread: using DE in a sand filter
    May 2016
    California
    2
    Hi,
    I am sure this has been discussed already, but my search terms (DE, sand, area) seem too generic to find the answer in the archives.
    I am looking into adding DE to my sand filter (Sta-Rite System 3, S8S70), and I have read that the small bags are better than the large ones (less mess).
    However I can't gauge the amount needed. My filter is 3.4 sqft, and the bags (EZ-DE Swimming Pool Diatomaceous Earth Filter Media) are sold for 36, 48, or 60 sqft DE filters.
    What is an optimal amount to use 2-3 times DE after backwash with my sand filter?
    Thanks!
    Gio
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: using DE in a sand filter
    Welcome to TFP!
    More here about adding DE to a sand filter, Pool School - Add DE to a Sand Filter
    Also, you can add your pool info to your signature so that we can better help you. More here, Pool School - Read This BEFORE You Post
    Jan 2012
    'burbs of Augusta, Georgia
    7,264
    You don't need much at all. Mine takes about 2 cups to raise the filter pressure 1psi. Of course each time you backwash you're removing that DE, so you'd have to start again.
    I'd just buy the smallest amount I could to try it.
    May 2016
    California
    2
    Thank you! My thread was moved and only now I saw your replies.
    Thanks!
    gio
    May 2016
    West Bloomfield, MI
    709
    I bought a 25 lb box of DE, which seems to be about a 25 year supply for my sand filter... Next spring I'm going to introduce myself to the pool owners down the street and hope they have a DE filter.
    12,000 gal Diamond Brite indoor​ pool. Pentair Triton TR-60 Sand Filter +added DE, Lochinvar Energyrite ERN-200 gas heater, Pentair Multi-valve, Pentair SuperFlo VS pump, TF-100 kit, Pool Math App - iOS
    Aug 2014
    Northern IL
    4,615
    Check the pricing. My 25# box was cheaper ($20.00) than the smaller bags at the pool store.
