Results 1 to 7 of 7
Thread: Algaeguard question
    Mkubacki's Avatar
    Aug 2016
    Bradner Ohio
    25
    Algaeguard question
    Just added algaeguard to pool and now a bunch of stuff is floating on the surface would this be dead algae?
    30,432
    Re: Algaeguard question
    Welcome to the forum. What is algaeguard?
    Quote Originally Posted by Mkubacki View Post
    That would be a foaming agent in the stuff you added. The philosophy around here is "if it ain't broke, don't fix it." So if your chlorine levels are maintained at an appropriate level and your PH is within range, life should be pretty good. If it's not, it's likely because something is out of whack, not because you're missing some magic potion. Adding something else leads to Cat-in-the-Hat syndrome, where you're looking for something new to add to counteract the last thing you added, and so on, and so on.... What are your chemical levels?
    Geebot
    Chicago, IL
    30K gal, InGround Plaster Finish, 3.5'-9.5', Maytronics S300 Cleaner
    Donldson's Avatar
    NW Ohio
    2,917
    Welcome to TFP!
    I'm right over in Wayne, so good to see another NW Ohio resident. To answer your question, many algaecides foam up when used and dirt blowing on the pool can discolor the white foam. It will be best to net it off the top until it stops happening. In the future, regular algaecide additions are not typically needed as maintaining proper chlorine levels will keep water clear in nearly all cases. I haven't added any algaecide to my water in over 5 years.
    JD - 28' Round Above Ground Pool, 17,000 Gallons. Dual speed Jacuzzi pump with cartridge filter. Dual speed 1 HP pump, Hayward S210T sand filter
    Pool School - PoolMath - HIGHLY Recommended Test Kits
    Mkubacki's Avatar
    Aug 2016
    Bradner Ohio
    25
    Had algae on bottom of pool have one of those lil 12' pool and it fluctuates to much only a couple more weeks left of season I'll just limp till then lol
    Mkubacki's Avatar
    Aug 2016
    Bradner Ohio
    25
    Going to be putting up a 27' above ground next year also!
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,286
    Read up on Pool School... You'll want to start your new one off right!
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
