Results 1 to 7 of 7
Thread: Should I be cleaning my filter 30days post new plaster?
    May 2015
    Fullerton, CA
    636
    Should I be cleaning the filter this soon? I know it's most likely has a ton of plaster dust.
    33x19, 3'4"-5'6", 7ft spa, baja reef, 14'x9', 18" deep, 10,668 Gal. Quartzite coping, Stonescape Tropics Blue mini-pebble, abalone & glass beads. Jandy Equip.(JXi heater, 2.7HPVS pump, PLC1400 SWG, CV580 filter, Aqualink, LEDs)
    TF-100, Doheny Discovery robot.
    38,301
    Re: Should I be cleaning my filter 30days post new plaster?
    Certainly plausible. We recommend cleaning the filter any time the pressure rises 20-25% over the clean pressure.
    bdavis466's Avatar
    Aug 2014
    Riverside, CA
    3,745
    Cleaning it just to clean it or because the pressure has risen?
    -Brian-
    33K Pool/Spa, Pentair Equipment
    POOL BUILD
    Davis Custom Construction - Home Page
    May 2015
    Fullerton, CA
    636
    Honestly, with everything going on i didnt even look at the start up pressure and i have changed rpm, so i dont have a baseline. At 1750 rpms i am @ 8psi on the gauge.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    I would clean the filter and make a note of the clean pressure at 3000 rpm for future reference.
    May 2015
    Fullerton, CA
    636
    Its running 18psi @ 3000 rpms.
    Killer95Stang's Avatar
    Sunny SoCal
    591
    I cleaned the filter a month or so after the pool was finished, just because I was curious and had the time to do so. At the bottom of the filter, it had a bunch of pebble rocks and other gunk that was probably from the build process. I would clean it at thirty days just to become familiar with your filter and to set a baseline of pressure like stated above.
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
