Thread: Replacing a motor
    Apr 2015
    herndon, va
    8
    Replacing a motor
    Hi,
    I am looking to replace my AO Smith motor (I think the bearings are gone - it's making a weird noise AND I broke the starter switch when investigating). I have one question - seems kinda stupid, but how do I get the diffuser off the drive shaft? The whole thing turns (obviously) but when I try and hold the shaft at the other end with a screw driver I just can't free it - is there some sort of trick I'm not trying?
    I'm also assuming the loud noise is the motor - I don't see what else it could be.........?
    Once I get the Diffuser/Impaller off, is it pretty simply to switch in the new motor - just looks like a rewire and then replace the parts?
    Feb 2009
    Hampstead, NC, transitioning to Perfection, NC
    360
    Re: Replacing a motor
    The shaft is likely left hand threaded...which way have been turning it?
    16X32 AB, Pentair SD filter, 3/4hp Pentair Optiflo, CircuPool RJ30+ swg, TF 100, 19 X 37 igv, Pentair filter, 1hp Pentair Superflo pump.
