Thread: Is it safe to swim with a little algae?
    Jun 2016
    Buffalo, NY
    65
    My pool is blue and clear and can easily see to the bottom.
    However, I just noticed there is a little bit of algae on a section of wide wall and also on one step of the stairs.
    I put 2 gallons of 8% bleach into the pool which raised FC to 25 and CC to 0.
    Is it safe for my kids to swim with the algae in there?
    12,000 gallon AG pool | Hayward 1HP pump | Hayward Perflex DE filter (I hate DE) | Taylor K-2006 Test Kit
    Jul 2015
    Central Valley CA
    1,108
    Re: Is it safe to swim with a little algae?
    Generally we say it is safe to swim if the water is clear up to SLAM level so a small amount of algae is not a problem however if your CYA level is at 60 or lower the FC concentration would be higher than I would be comfortable with.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    Jun 2016
    Buffalo, NY
    65
    Quote Originally Posted by atttech-2 View Post
    Yeah I'm OK with the FC because CYA is at 100.
    I'm just concerned about the algae.
    jeffchap's Avatar
    Jun 2012
    Edmond OK
    1,527
    Algae by itself isn't really harmful, AFAIK. People swim in rivers and lakes all the time, and they are full of algae. The problem is that if your chlorine is low enough to allow algae to grow, it's too low to kill off the other pathogens (bacteria, viruses, and amoebae) that might also be growing in your water.
    25000 gallon free-form gunite
    Jandy Stealth pump/CL340 cartridge filter
    Pentair IC40 SWG
    Pentair MasterTemp 250HD heater
    Jandy AquaLink RS automation
    Mod Squad pooldv's Avatar
    DFW, TX
    24,497
    It is fine to swim with a little algae, as long as FC is above minimum for your CYA to kill pathogens that can lead to person to person disease transmission.
