Results 1 to 8 of 8
Thread: Can high FC damage equipment?
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Most of us have heard this argument against the FC/CYA ratio; FC over 4ppm will damage pool equipment. This is even included as a clause some equipment warranties. We all know this isn't true as long as there is CYA in the water.
    But I'm not asking about SLAM FC levels. The situation is that I am working with a 120k gallon commercial pool that gets drained every single season. Due poor management of chlorine deliveries, we are stuck with about 80 gallons of liquid at the end of this season, and I am trying to figure out what to do with it.
    The stenner pump is a bit oversized for this pool, I generally only keep it at a 1.5 or 2 to maintain 3-5FC. The dial goes all the way to 10, and it would deplete the 80 gallons in a day or two if I cranked it up. However, I could see the FC easily getting into the 40-60ppm range doing this. Could that damage any pump/equipment? There is about 40ppm CYA in the water. Alternatively, I thought about slowly diluting and draining the remainder somehow. How would you handle this?
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Jul 2015
    Central Valley CA
    1,107
    Re: Can high FC damage equipment?
    40 to 60 ppm sounds absolutely caustic I would not do that. If you have a couple of weeks after it is closed to the public but before it is drained perhaps you could bring it up to SLAM and let it burn off slowly without being out of compliance for any health dept codes since no one will be swimming.
    Or Tell everyone you know to provide an empty Clorox jug or something similar and you will fill them up for general household use.
    12,300 Gallon, IG PebbleFina, 3 ft sheer, 2 Jandy nicheless LED lights, Jandy Pro 1.5HP VS pump (A.O. Smith Motor), PB4-60 Booster pump, Polaris 280, Jandy cv340 cartridge filter, Zodiac Z4 control panel W/iAquaLink, Stenner pumps for chlorine & MA connected to WiOn WiFi switches, TF-100. You can support TFP with AmazonSmile just click the link!
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by atttech-2 View Post
    I figured as much. I can probably get it down in about a week at SLAM levels.
    I also need to purchase a chem transfer pump. If I did this and pumped it out into 5 gallon buckets, how much would I need to dilute to dispose of it in a drain?
    Test Kits:
    My Pool:
    Jul 2015
    Central Valley CA
    1,107
    If you are going to dispose of it SLAM and wait is the best method I think of
    If you were to try to just dump it Clorox recommends 1/2 cup of 8% for a load of laundry and the average non HE machine uses 40 gallons so based on that I would say 1000:1 since most people use more than they are supposed to. You might be able to go 500:1 but your local water treatment department would not like you very much as most of them use microbes somewhere in the process of dealing wiht sewage.
    I had one other though check with a local hotel they may take it off your hands if they do their own laundry or put you in touch wiht the company they use. Might even be able to get a little money for it.
    Sep 2013
    Connecticut
    728
    Is the commercial pool outdoors or indoors?
    18' x 48" ring top pool (Summer Escapes); 5500 gallons; set up June - October, stored during winter; Intex 2500 gph pump (B size cartridge filter) Hayward 21" sand filter + 1.5 hp single speed Powerflo Matrix pump (upgrade October 2016) *** K-2006 test kit, refills from tftestkits
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by singingpond View Post
    Outdoor
    Test Kits:
    My Pool:
    Sep 2013
    Connecticut
    728
    OK, never mind then -- just wanted to make sure that the SLAM approach, and letting FC drift down, would actually work in a reasonable time frame.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    ok...the supply is going down quicker than I thought keeping things at 15-20PPM FC - down to 20 gallons
    Test Kits:
    My Pool:
