Results 1 to 12 of 12
Thread: What is this stuff settling on my pool bottom
    Jun 2015
    Wheatfield, IN
    37
    2nd year for the above ground pool and it's been pretty easy to maintain. But for the most part of the summer I have been fighting this stuff settling to the floor. it's only on the bottom, if I brush it just turns to dust. If I vacuume on filter it settles to the bottom again over the next few days. Pool head been clear all year and I just maintain my chlorine and do all my testing every free weeks and never a hint of problem with cc's or algae. Just wondering if I have a filter problem but that don't makes sense either because the water has been clear all year.<a data-cke-saved-href="http://" href="http://">http://[URL="http://s248.photobucket.com/user/bronzeback5/media/Mobile%20Uploads/IMG_20160906_132127646.jpg.html"][/URL]</a>
    18' round above ground est 8600 /gal with Hayward sand filter filled with well water
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    926
    Re: What is this stuff settling on my pool bottom
    Pretty sure that IS algae. Do you test your water with a test kit (not at the pool store)?
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    Jun 2015
    Wheatfield, IN
    37
    I have a test kit. Does algae turn to brown dust when brushed?
    30,414
    Quote Originally Posted by Bronzeback5 View Post
    Yes it does, and that's dead algae....due to chronic low chlorine in your pool. If you have a good test kit with FAS/DPD chlorine test, you need to SLAM your pool. See the SLAM article in Pool School
    Jun 2015
    Wheatfield, IN
    37
    So when I do the chlorine test it should indicate something is growing in my pool?
    Buddy from work said mustard algae when I explained it to him. Just stopped by the pool store and she said mustard algae also and I need a product called Banish I believe.
    I am familiar with slamming and I will do the chlorine test before dark tonightAnd see what it says.
    Banish is copper. Not something we recommend. Stick with a proper Slam and follow with good chlorine levels. You're getting persistent algae due to insufficient chlorine.
    Support the site
    Jun 2015
    Wheatfield, IN
    37
    Alright, pH is 7.4 after I lowered it.
    CYA is 30. Thought I was closer to 50 but draining the rain water this last month must have took me down.
    FC 25 after I bumped it up
    CC is .5 as it was just the tiniest hint of pink after I added the R-0003
    I was thinking dead algae but that's what had me puzzled was why I could not vacuume it up and be done if it's not a growing problem?
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    926
    Because it likely is a growing problem! Trust me... been there! Don't add all that pool store stuff. You just need bleach and the SLAM procedure as described on this forum.
    Dead algae comes from live algae. You're getting live algae at some point and then it dies. Full Slam followed by very consistent fc levels that never go below recommend levels is the best course of action.
    Support the site
    Jun 2015
    Wheatfield, IN
    37
    I'm slamming now and will continue. Have been pretty good about keeping the chlorine between 4-7 and with a cya that dropped to 30 I know that my chlorine levels have been good. How do I get rid of the dead algae since filtering had not seemed to work?
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    926
    Brush, brush, brush. Keep that stuff floating so your filter can remove it. Vacuum when you can, and slam as per the instructions in Pool School.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,483
    Please add your pool info to your signature so that we can better help you. More here on what to add and how to do it, Pool School - Read This BEFORE You Post
    If you have a sand filter you can add some DE to help it better filter out the dead algae.
