Results 1 to 9 of 9
Thread: Clean or replace Intex cartridge?
    Aug 2016
    Pace/FL
    49
    I just bought a 22' ft. Intex pool and clean my cartridge frequently. While battling a slightly cloudy pool I began to think that I may need to replace the cartridge even though I clean it regularly with my hose.
    So even if I clean it often, do I still need to replace? If so, how often?
    Thank you.
    22' Intex AG - 12K Gallons
    Model 633T Cartridge Pump
    August 17, 2016
    Jun 2014
    15,070
    Re: Clean or replace Intex cartridge?
    If the cartridge itself is not torn or shows any sign of physical damage, it's probably still good. Your biggest challenge with the Intex-type filters is they are a bit small and have a limited capacity, so frequent cleaning may be the norm for you. Still, a good steady high-pressure nozzle rinse should be fine. The best thing you can do, if not already, is ensure the water chemistry is good by testing with a TF-100 or Taylor K-2006C. While the filter is designed to catch physical debris (bugs, leaves, etc), it's not designed to kill or clear algae. By testing your water properly, you will take a lot of stress off of your filter by having clear/sanitized water.
    Jul 2012
    SE Minnesota
    137
    Exactly what Texas Splash said. I would however replace the Intex cartridge with a Unicel cartridge. They seem to work much better at collecting the fine particles (dead algae?) that are causing the cloudiness.
    Intex Ultra Frame 26'x52"
    Intex 2,500 gal/hr pump with Unicel cartridge filter.
    Oct 2014
    Beaumont, CA
    47
    I generally get a season (almost 2) out of my Unicel or Filbur cartridges. I rinse them weekly and they work great
    16x48 Summer Escapes Pro-Series Above Ground frame pool, 5000 gal, Intex sand filter - Looking for heating solutions for AGPs
    Jun 2014
    Windsor Mill, Maryland, USA
    12
    This summer I've only used two cartridges - cartridges from Walmart (Summer Escapes?)
    When I changed the cartridge the first time, I took the used one, rinsed it out real well in the laundry tub then dumped it in a bucket of hot water with some Oxyclean. Weighed that critter down with a full bottle of bleach to hold it under water. Left it overnight (or a couple days if I forgot....). Rinsed it out good again, and left it in the dry bucket until I needed it. I change the cartridge maybe once a week.
    Suzy
    Intex Metal Frame Pool - 15' x 48" - 4440 gallons, with the Krystal Clear Cartridge Filter Pump 1500 gph
    Intex Krystal Clear Saltwater System - 7000 gallons. TF-100 test kit
    Installed June 2014 - complete newbie to pool ownership
    Aug 2016
    Pace/FL
    49
    Even though my pool is pretty clear, everytime I clean the filter I notice the water in the pump does appear somewhat milky, although it's improving. Which Unicel filter will work with my 2500G Intex pump?
    August 17, 2016
    Jul 2012
    SE Minnesota
    137
    Quote Originally Posted by fralo View Post
    I will check the number tonight. I have the same filter you have.
    Oct 2014
    Beaumont, CA
    47
    Measure the height
    8" Tall >> Type A or UNICEL C-4607 or Filbur FC-3710
    10" Tall >> Type B or UNICEL C-5315
    ta2dwonderwoman's Avatar
    Jul 2016
    fall river ks
    499
    I guess I've been a little over diligent then because I put a new filter in at least once a week... I plan to switch to sand for next year if all goes as planned but if not at least I know I'll save money on cartridges now!
    Windy ☆ 22ft round, 11,400 gal, intex ag vinyl, SF70110-1 Intex sand filter/2800 gph pump, CS8110 intex swg, city water, solar heater, TF100 test kit/speed stirrer, over the wall intex skimmer~fall river ks~SLAM, Pool School, Recommended Levels, Recommended Chemicals, Pool Math
