Thread: pH Level for SLAM'ing
    clmsntiger1's Avatar
    Apr 2016
    Lexington, KY
    22
    I have a question about pH level for SLAM'ing. I know pool school calls for a pH between 7.2 and 7.5 before starting the process. How does a higher pH (7.8 for instance) affect the SLAM process?
    16x32, IG, vinyl, 23,500 gallons with Hayward S-244T sand filter,
    1.65 HP VS Pump, using TF-100 test kit
    Jan 2012
    'burbs of Augusta, Georgia
    7,373
    Re: pH Level for SLAM'ing
    I believe chlorine's killer power is optimized at 7.2-7.4 range.
    Also, knowing that once you raise your FC over 10 that the pH test is invalidated you'll know your pH is in order if you've put it at that lower range at the onset of the SLAM.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Guess who:
    Quote Originally Posted by chem geek View Post
    If one is going to shock at high levels using a hypochlorite source of chlorine (bleach, chlorinating liquid, Cal-Hypo, lithium hypochlorite), then one should lower the pH first before doing so. Adding chlorine raises the pH. Though it will come back down when the FC level drops, you don't want the pH to get too high because it can precipitate metals that can cause staining, can cause cloudiness from over-saturation of calcium carbonate, and at much higher pH the active chlorine level goes down significantly.
    Algae bloom while getting CYA down to manageable levels
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Apr 2016
    Lexington, KY
    22
    Thanks for the replies! It sounds like it doesn't adversely affect the actual process of killing the algae unless the pH gets really high, but could impact the clarity of the water or cause staining.
