Thread: Best way to scrape calcium deposits off plaster-- pumice stone or something else?
    Jun 2016
    Western Connecticut
    47
    Hi. I have areas of my plaster pool that have calcium deposits on it. Nothing serious, but little tiny pebbles (maybe the size of a pinhead or maybe slightly larger).
    I tried the wire brush that I got with the pool, but that does not do anything. I bought pumice stones online, but maybe I bought the wrong ones, but they seem to disintegrate in the water as I am scrubbing (is that normal)?
    What other type of stone can I use to get the calcium off but will not harm the plaster? Thanks
    32,500 gallon in ground Gunite/White Plaster, Pentair Cartridge Filter, Pentair Propane Heater, Pentair Racer robot cleaner
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Best way to scrape calcium deposits off plaster-- pumice stone or something else?
    Yes, it is normal for a pumice stone to leave behind lots of pumice. You can use wet/dry sandpaper.
    Jun 2016
    Western Connecticut
    47
    Quote Originally Posted by pooldv View Post
    Hi. What grit do you recommend? Thanks
    DFW, TX
    24,450
    80 to 100 grit
