Thread: Newly moved to SC and first time owning a below ground pool
    Sep 2016
    Goose Creek/South Carolina
    3
    Hello everyone. We just moved to SC from MD and have never owned a below ground pool. The pool was not running for over 8 months before we moved in and had a small tear in the cover. So, it looked like nasty muddy swamp water when we uncovered it. We have the chemicals at a perfect level, but it is taking a while for the cloudiness to go away. But, our main problem is vacuuming it. So, I am sure I will be spending quite some time on those types of threads.
    Mr Bruce's Avatar
    Mar 2014
    Greenville, SC
    2,088
    Re: Newly moved to SC and first time owning a below ground pool
    Welcome! I was hoping for another Upstater but oh well Joking!
    If you fill out your signature with your pool and pump info and post some test results we'll be glad to help.
    32K gallon Plaster - CircuPool SJ-55 SWG - 1hp Hayward 2 speed Super Pump - Hayward S200 Sand Filter - TF100XL/K-1766
    Test Kits - Pool Math - Chlorine/CYA/Target/Slam Chart - Support TFP
    Sep 2016
    3
    Thank you. I am trying to figure all that info out, but will post what I know as of now.
    Sep 2016
    3
    I don't know my test results, I took the water in to Leslie's this morning and they said all my numbers were perfect. But, the water is cloudy and bluish in color. They said it would take a little time for that to clear up since the pool was sitting with no chemicals, pump not running, and a rip in the cover for over 8 months. It was disgusting when we took the cover off, lol. We have only had the pool up and running for about 3 weeks now and it looks 100% better than it did. My only problem is the vacuuming. I cannot get the water to stay in the hose before I get it in the skimmer hole.
    In-ground, 15340 gallons, sand filter; Hayward Pro, self priming pump; Hayward as well.
