Thread: Pool equipment storage
    Apr 2016
    Derby, KS
    23
    Just wondering what everyone does with their pool equipment over the winter. I live in Central Kansas so it does get cold and snowy. I have the pump, booster pump and a SWG. Should i disconnect these and bring them inside or is there a better way to store them? Will they be OK left on or will they wear out faster that way? Thanks in advance!
    25,000 Gallon Vinyl in-ground pool. Pentair 1.5 HP superflo, Hayward S244T sand filter, Polaris PB4-60 booster pump, Intellichlor IC40 SWG
    borjis's Avatar
    Aug 2014
    Pacific NW
    2,329
    Re: Pool equipment storage
    All my equipment is in a shed attached to the house, but if I had it exposed to the elements I would disconnect
    and store them in the garage.
    Dolphin E10 Cleaning Robot.
    Sep 2015
    Rome, NY
    363
    Last year was our first year. I took all the hoses off, removed all the plugs and then covered everything. All that stuff went inside the garage. Pump stayed outside and I did not remove the valve spider gasket. I wonder if I need to remove the gasket this year?
    Pool installed 8/2015. 30' round Radiant pool. 21,000 gallons. 200# sand. Hayward Vari flow XL valve. 1.5hp Hayward Power-Flo Matrix running 10 hours/day in two periods. TF100 with speed stir. Sun all day, south side of house
    Order test kit TF-100 w/ Speed Stir and then Poolmath Calculator --- RECOMMENDED LEVELS --- POOL SCHOOL --- Algae? --- Chlorine/CYA CHART.
    Sep 2015
    Rome, NY
    363
    Would you remove the spider gasket?
    i left it all outside covered with a tarp last year.
