Thread: Concrete Sealer
    Jun 2015
    Kingston ma
    56
    Concrete Sealer
    Looking for a recommendation on a concrete sealer for my stamped concrete pool? Tried searching to forum but haven't seen any newer threads...
    thanks in advance
    Mike
    20x40 kidney IG vinyl liner built 2012
    27k gallon, Pentair IC60 SWG,
    pentair vs 3hp pump, triton sand filter
    JoyfulNoise's Avatar
    May 2015
    13,176
    Re: Concrete Sealer
    Either DuPont StoneTech or DryTreat Stain-Proof Original products are probably the most widely recommended. They do cost a significant amount of coin though so if you have a lot of concrete to seal, it could get costly...but probably less expensive than hammering out cracked concrete from freeze-thaw damage....
    Matt
