Thread: High CYA/FC - about to drain/refill, what are next steps
    Sep 2016
    Houston, TX
    31
    Current reading from Taylor 2006:
    FC 27.5
    CC .5
    pH 7.8
    TA 150
    CH 275
    CYA 140
    I'm going to drain about 70-80% and try to get to CYA of 40. Assuming CYA measures at or around target after refill, what part of my chemistry is my next item to focus on?
    15K gal rectangle with 1K gal spill over round spa | K-2006 Test kit | IG plaster | B2983 1.5HP 2 speed pump| Triton TR100 sand filter | Pentair MiniMax 400k BTU heater | Stenner 45MPHP10 w/ 15g tank | Dolphin M400 robot | screened pool cage covers pool entirely to keep it debris free and adds SPF | sun exposure estimate 8hr daily.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    7,493
    Re: High CYA/FC - about to drain/refill, what are next steps
    Since all your readings will change after your water exchange, the best bet is to run another set of tests once you have the new water in. The results of that test, will answer your question.
    That is the whole point of the TFP process.. Measure and then take only the actions needed to correct any reading that is out of balance..
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,023
    Just a warning... I ended up having to do two drains because the first time, I was relying on the diluted CYA test and underestimated how high my CYA really was. Might want to go to 80% rather than 70.
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
