Thread: Pool pump starting issue
    Sep 2016
    Bloomfield/MI
    1
    I have a ITT Marlow 1 1/2 J75EC10 pump. It is hooked to a intermatic timer. Several weeks ago the pump seemed to hesitate when switched on. I cleaned off the wires to the timer terminals and replaced the terminal screws. That helped for awhile. Now when I switch the pump on there is a humming sound for about 10 seconds, then it stops. It goes through that same cycle after about a 30 second delay. After three or four cycles, the pump starts. After about an hour the pump stops again. There is power coming in to the timer. The circuit breakers have not shut off so I don't think there is a short. Haven't checked the capacitor (on top of the pump) to see if it is starting to fail. Any thoughts?
    Aug 2013
    Oklahoma City, OK
    140
    Re: Pool pump starting issue
    Check the capacitor. I just had to replace mine on my pentair pump that is less than a year old. If it isn't the capacitor then the winding's in the motor are probably bad and it is time to either repair or replace the pump.
    20000 Gallon, Sand Filter, IG Plaster, Hayward Aqua Rite 40k SWG, TF-100 Test Kit, Taylor SpeedStir
